diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Hookup Wire Q (http://www.diyaudio.com/forums/chip-amps/90830-hookup-wire.html)
matthewm 22nd November 2006 11:58 AM
Hookup Wire Q
I have a twisted pear revc and joshua tree setup in my case, im wondering what would be the best sort of hookup cable to use between the rca input to joshua tree (about 1 inch) then to the amps (ranges from 1 inch to 4 inches apart) I dont really want to spend that much, and im in Australia so any local help would be appreciated ie where you got your wire etc etc
Would generic hook-up wire be ok? What do ppl usually use?
Matt
Nuuk 22nd November 2006 01:15 PM
Yes good old 0.6mm diameter equipment (hook-up) wire is fine. At those sort of lengths it really doesn't matter.
Australia? Local? Does anybody love 'locally' down there? :D
AndrewT 22nd November 2006 04:07 PM
a twisted pair into the twisted pear seems sensible but in only 25mm you will probably only manage 1.5 twists.
In 100mm you could get 6 to 8 twists.
CarlosT 22nd November 2006 05:06 PM
I saw some cheap "thermostat" solid 18 gauge wire at the Home Depot...would this work for both signal and DC power wires?
Resources saved on this page: MySQL 18.75%
