Help with blown Fuses LM3886, Chipamp.com
Old 23rd November 2006, 07:57 AM   #21
R.I.P.
it's a bit difficult to tell but it looks, on my monitor, that a few isolated high points have worn through the insulation.
Shrink wrap or anything similar would be most unusual for the outer covering.
They are usually wrapped in a very tough (much tougher than sellotape) strip of plastic tape (without adhesive).
The wrap is done with a 55% overlap at the outside perimeter and this results in about 70% overlap at the bore. This ensures that at least two layers of insulation are present at the outer edge but due to the way the copper is wound the inner layers are always fatter and these ones would suffer damage. It just happens that these inner edges of the turns get at least three layers of insulation using the 55% overlap rule.
Some manufacturers will wrap the outer twice, giving six layers of insulation at the most vulnerable points (the fat bit).
This is quite a skilled job and needs many tens of metres of insulation but can be done at home if you can source the tape.
Fit the rubber washer.
AND
Insulate the top washer plate and bolt head so that accidental shorted turn CANNOT happen.
regards Andrew T.
Old 23rd November 2006, 02:23 PM   #22
davidlzimmer is offline davidlzimmer  United States
Just my 2 cents.
I'd get another transformer for now. You can repair the old one while listening to great sounds.
Rarely does one just build ONE chip amp. The old one can be repaired at your leisure and used in your next project after thorough testing.
Poor stereo mix? Switch to mono! Perfect.
Help with blown Fuses LM3886, Chipamp.comHide this!Advertise here!
A couple questions about blown output fuses, and protection (Rotel RT-990BX) terasearch Solid State 3 2nd August 2009 11:50 AM
LM3886 amp started blowing fuses. Where do I start? bluegti Chip Amps 14 1st June 2009 02:31 PM
NAD AMP.....sound distorted....fuses blown linton Solid State 10 11th November 2006 06:36 AM
Buzz, then blown fuses DrStrangelove Tubes / Valves 20 18th May 2003 09:49 PM
