Old 21st November 2006, 11:33 AM   #1
Alfetta87's Avatar
Default LM4780 (LM3886) impedance issues
The national semiconductor datasheet doesn't say if the bridged (or parallel) application of the LM4780 would hold on with a 4 ohms load, even with its maixmum voltage used.
Has anybody got some experience with that?
Same for the LM3886 in brdiged mode.
Thanks,
- dan
It is worth to keep your mouth shut and let people think you’re stupid; rather than to open it and thus eliminate any doubts...
Old 21st November 2006, 02:35 PM   #2
jackinnj's Avatar
If you look at the "overture design tool" on National's website you can quickly determine the heat sink rating for a given rail voltage and impedance.
You can play around with the numbers and determine which heat sink/rail voltage combination is appropriate -- there's no need to guess.
I have used the LM4780 at higher PDMax than recommended by National by using forced air through the heat sink -- be mindful this causes the thermal protection to cycle on-and-off -- it's a nice experiment but something that you shouldn't try at home on your expensive speakers.
Using a lm4780 instead of 2x lm3886? nicku1302 Chip Amps 10 12th November 2007 02:36 AM
Switch impedance issues in Wallin 2 Jig Dave Bullet Multi-Way 9 28th May 2007 10:13 PM
MTM Impedance Issues matt09 Multi-Way 10 10th August 2006 03:13 PM
LM3886 & PGA2310 issues Xlrator Chip Amps 0 7th March 2006 07:25 AM
lm3886, lm4780, elementx Swap Meet 4 29th December 2005 02:44 AM
Page generated in 0.10475 seconds (56.30% PHP - 43.70% MySQL) with 10 queries
