| Chip Amps Amplifiers based on integrated circuits |
Hi!
Planning to build my LM3886 soon, also planing to build a pair of speakers for it. Does the LM 3886 prefer 4ohms or 8ohms drivers? Thanks. |
#2 |
8 Ohm definately.
I recently completed 4 channels and made the mistake of getting the plastic parts for convenience. Also, I'm running at 35-0-35 when you should run at 28-0-28 if you use 4 ohm. I'm running it on my Jamo's which are 4ohm and these chips are getting HOT! I have a very big heatsink on them, but the losses on the plastic package is too high, so it cannot transfer the heat quick enough. They sound quite good though, for incase you didn't know
The walls between art and engineering exist only in our minds - Theo Jansen |
#3 |
4 0hms is ok for the LM3886. See http://www.national.com/pf/LM/LM3886.html
#4 |
depends on the supply.
For 4 Ohm speaker, LM3875 run fine at +/- 24V while the LM3886 can run with +/- 28V. If you have good & big heatsink, I run LM3886 with +/-35V on 4Ohm speaker happily. |
#5 |
It's all depends on your power supply and heatsink.
#6 |
I guess I don't understand the power supply voltage issue. I heard a few times now that 4 ohm loads work better with lower voltages. Is this because the load is drawing more power and a lower voltage power supply keeps things under control? Even if you have a high voltage power supply, couldn't one compensate by reducing the gain...playing with the feedback resistor? Excuse my ignorance...I'm very new at this
#7 |
Thanks for the replies,
reason for me asking is that I have a lot of 4 ohms drivers lying about from the car audio days and if the LM3886 GC can run them, I'd be saving some speaker building $$$.
#8 |
Again, I'm speaking from the experience I had and from what I read.
Apparently you keep the voltage lower into 4 ohms to prevent heat spots building up on the chip. There is not a hell of a lot of dissipation area on the chip, so there is not a lot of contact surface area to dissipate heat. You can have as big a heatsink as you want, the thermal footprint of the chip is still small! I think my heatsinks are big enough ![]() ![]() By using 28-0-28V supplies, you limit the dissipation in the chip if you want to run 4 ohms. When I first read it I didn't take it too seriously, but now that I've run it for a while I realised they were quite serious about it! The point I was trying to make (like an idiot, I must say!) is that if you were to run 4 ohms, you need to have your PSU at 28-0-28V AND you shouldn't use the plastic package. Use the metal tab version instead. I hope I haven't confused the issue any more
#9 |
Think of the load at the end of your amp as being powered....
remember all the power doesn't go to the load, but it DOES go to the chip, so if you hit the chip's maximum level, you will likely overheat it it and burn it out. The minimum rateing for lm3886 is about 7 AMP (you can look it up in datasheet) - this means with variations between chips, they should not blow up till they reach at least 7 ampere - in fact it shows a possible maximum up to 11A depending on the chip in your hand. now take your load (speaker/driver) and divide it into the supply you got hooked up. 40V (almost max for lm3875 level) would on lm3875 run into 8 ohms. 40/8 = 5amps at 40V for the lm3886 you can see that 4ohms x 7ampere = 28V. (as it is the minimum figure - remember some could make it to 11A) so it could in theory run onslightly higher rails.... But it should make the whole thing transparent to you for future use. |
#10 | |
| 4ohms and 8ohms speaker drivers | bng | Multi-Way | 2 | 31st December 2008 12:48 AM |
| 100w into 4ohms? | Powertimes_2 | Solid State | 4 | 1st December 2008 11:50 PM |
| Have to mod K-502 to 4Ohms from 8 | udailey | Tubes / Valves | 1 | 13th March 2008 03:27 AM |
| WTB: Vifa P17 4ohms | AR2 | Swap Meet | 1 | 13th October 2006 03:53 PM |
| My first pre-amp for my LM3886GC | Russ White | Chip Amps | 7 | 23rd March 2005 08:47 AM |
| Page generated in 0.14969 seconds (59.46% PHP - 40.54% MySQL) with 10 queries |
