diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   opa541 schematic (http://www.diyaudio.com/forums/chip-amps/90675-opa541-schematic.html)
s_pics 20th November 2006 07:32 AM
opa541 schematic
2 Attachment(s)
I need to know if this is OK.
I drew this schematic And I want to know if it's good
so it should have a 12.5gain right?
and 8ohm as a speaker should be good?
I will need something like a 3 or 5 W res for R4, sould I use another res value?
maybe I need to put a capicitor between ground and R2
tell me want you think about it
thanks
simon
Nuuk 20th November 2006 09:09 AM
Your resistor valvues are too high and it is best to keep the maximum gain to 10! And you are missing the connection from pin 8 to the output! :att'n:
Below is what I used and it works very well. ;)
http://nickw.worldonline.co.uk/etc/opa541.jpg
pwan 21st November 2006 05:07 AM
Agreed with Nuuk's on the max gain ( Sawaddee Nuuk!)
However, Be remind that the using 22K/680 (shown in the picture) have x33 gain which heavily degrade the mid & high. To get max gain 10, I personally try 10K/1K on feedback, and change Ri to 10K --> directly feed by CD player via 50K pot. it run beautifully.
Nuuk 21st November 2006 09:28 AM
Sawaddee Pwan,
Quite right about the resistor values! I forgot to add that I am using 10K and 1K3. :)
s_pics 21st November 2006 06:07 PM
thanks guy,
what about C1/R3 is that some kind of filter?
is the value of C2 and C3 1000uF?
Nuuk 21st November 2006 06:47 PM
C1 is the DC blocking cap and R3 a resitor to ground (in case you use the amp without the volume control).
The big caps can be anything really but I found 1000uF worked very well. I have always used Panasonic FCs but now like the Panasonic for Audio types! :)
pwan 21st November 2006 07:28 PM
Nuuk,
Have you ever tried Nichicon "UPW" from mouser? It looks even better than FCs on paper esp. life time.
Nuuk 21st November 2006 09:51 PM
No, ordering from Mouser isn't really practical from the UK. But I'll keep an eye out for them over here. ;)
s_pics 29th November 2006 01:20 AM
now working on the power supply
So I am done with the amplificator circuit, i've made two of them and tried them on a computer power supply +12V/-12V it worked fine, but im not sure is it for an 8ohms spk?
anyway now i'm working on the power supply I just figured out how to obtain a negative tension out of a transformator.
now my questions are is this power supply a +28V 0V -28V? here is the link :http://cgi.ebay.ca/28-28V-500VA-Toro...QQcmdZViewItem
then is 500 VA mean 500Watts?
then is that going to be too much power, should i go with less powerful, if yes then what is the minimum i can use
thanks your time
I will post some pics of my work later on
simon
Easyamp 29th November 2006 01:47 AM
nuuk not sure I understand your gain factor
Your resistor values are too high and it is best to keep the maximum gain to 10!
If your input was 1 volt and your amps gain was 1*10 that would net generally about 11 volts rms out. Now 1 volt input is not outrages but you'll usually find .6 to.8 volt levels in home audio equipment.
The opa541 is quite capable of more than 100 watts into a 4 ohm load which you will not get close to at this gain level.
I agree the high value resistors used in the original schematic are too high in value but not in relationship for feedback.
feedback needs revision
Copyright 1999-2017 diyAudio
