good and simple preamp for Gainclone
Old 24th April 2007, 04:57 PM   #101
sansbury is offline sansbury  United States
Gajanan- Thanks! I've heard that explanation before, and many others, but I still don't have an instinctive sense of it, the way I do of say voltage or current. One day though I will get it
Owen- I tried hooking up to the GC last night, and I am stumped by what I should be hearing. The volume level is much lower versus plugging the line out on the CD player directly into the amp, though it can certainly still make plenty of noise. But, the sonic qualities seem to be about the same whether I have the batteries attached to the buffer or not, as far as I can tell.
Is there any tell-tale sign I should be looking for? It was late so I didn't test that much or push anything too hard. I'm just wondering how I should know when in fact everything is working.
Old 24th April 2007, 05:08 PM   #102
are you saying the buffer lets through the same signal irrespective of whether the batteries are supplying the opamp or not?
That sounds like a miss-wire somewhere.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th April 2007, 06:29 PM   #103
AndrewT- as you may notice if you start back 50 or so posts in this thread, we have been playing "find that fault" in this very simple circuit for about two months now.
To answer your question, yes, the signal seems pretty much the same whether power is on or off. That, plus the drop in volume (which I am assuming would not occur if the buffer were applying true unity gain?) leads me to the same conclusion.
Given the by-now miniscule parts count, it seems clear that we are overlooking something fantastically simple and obvious that would no doubt have revealed itself long ago in person. I am going to post some high-res picks of the thing in the next day or two and will submit any test inputs/outputs people want to know about--I have a scope now so I should be able to show people anything they might want.
good and simple preamp for GaincloneHide this!Advertise here!
Simple pre-amp for gainclone help req'd. LucasAdamson Chip Amps 31 16th September 2009 11:31 PM
Pass B1 Passive Buffer Preamp. A good and simple option for chipamps?. A Sanchez Chip Amps 5 2nd January 2009 05:34 PM
good simple DAC kit? cowanrg Digital Source 61 9th October 2006 09:32 PM
need good but simple amp sidd_raj2002 Chip Amps 13 1st February 2005 02:35 PM
very simple gainclone questions wrl Chip Amps 4 23rd June 2003 07:01 AM
Copyright ©1999-2017 diyAudio
