Old 18th November 2006, 06:42 AM   #1
Dan2 is offline Dan2  South Africa
Default 5.1 volume control
i don't know if this is the right forum - i have a question concerning a pre-amp.
i want to build a master volume control for 5.1 channel setup- i just don't know where to start. pls help
Old 18th November 2006, 07:01 AM   #2
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Here some IC's from princeton technology
http://www.princeton.com.tw/webSite/...t_level2_id=17
PT2258, PT2325, PT2327. One of my friend tried PT2258. Its very good IC and has very low distortion and Noise.. The others are controlled by DC but it has a MCU interface.. I recommend PT2258..
Old 19th November 2006, 07:35 AM   #3
thanks man- this is exactly what i am looking for.
Old 19th November 2006, 01:35 PM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
Wim Bouman,(MR TUBE) has some completed assemblies available right here in the RS of A.
Remember that we stock the Chinese made remote controlled volume controls, many of those have meanwhile been sold and I have only had positive feedback from those of you that bought one of these.
The set comprises a remote operated ALPS volume control, mated with an input selector board using sealed, Japanese made relays, and complete with remote handset.
As an option you can also get a mounting bracket plus an extended shaft for the volume control.
Two types are available, one that caters mainly for the stereo plus balanced line input variety and another one that does the same but can also be used with 5.1 surround sound applications.
The first type uses a 100k log double stereo (4) ALPS pot, the 5.1 version uses a 100k triple stereo (6) pot.
They are identical otherwise.
Both come complete with a remote handset, variable speed control selection of the volume control, mute function, auto mute when changing inputs, and LED output to indicate the status of your input selection.
Also included are the infrared receiver/transmitter and a manual rotary switch selector for the inputs.
Here are the prices:
Four channel input board, dual stereo volume control, remote handset, selling for R 640,00
As above but triple stereo 5.1 configuration, R 680,00.
Add R 40,00 for the mounting bracket plus extended shaft kit.
This includes all the bits and pieces plus some of the interconnecting cabling except the batteries for the handset.
Drop me a smessage if you'd like his number.
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
The remote control paratactic volume control audio-gd Solid State 33 7th June 2007 11:16 PM
PC volume control sumacSK Chip Amps 9 28th November 2005 05:33 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Page generated in 0.08583 seconds (69.66% PHP - 30.34% MySQL) with 10 queries
