Old 17th November 2006, 06:57 AM   #1
CJ900RR is offline CJ900RR  Sweden
Default BPA200, replacing LF412ACN with?
Thinking of constructing a pcb based on the BPA200 in Nationals AN1192.
My simple question is, can I replace the LF412ACN with LM4562 straight forward, or do I have to re-calculate the values on other components to?
Best regards, Calle...
Old 20th November 2006, 01:00 PM   #2
tlmadsen's Avatar
HI Calle
Normaly you should be able to replace LF413 with all most any other DUAL op-amp, but why would you. ??
It is part of the DC-servo, so the only real important parameter is its offset. Something like the AD712 (I think it is called) might be better in that respect.
Your DC-servo will not sound "better" by putting a fancy Dual op-amp into it.
I have no problem using a DC-servo (see some of my other replys), but people that don't like them are normally against the hole "topology" more than a single component.
Have fun
Old 20th November 2006, 01:20 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
The servo opamp will feed back audio signals up to 500 Hz to 1 kHz. So it must be good in those frequenies which most decent opamps are. Over 100 Hz a very small part of the audio signal goes through the servo. As Thomas says almost any opamp will fit. Personally I chosen an AN8620 as a buffer + servo and for the servo part it's massive overkill but it's nice with 80 uV offset! You can see my implementaion of AN-1192 at my homepage.
/Per-Anders (my first name) or P-A as my friends call me
Old 20th November 2006, 01:20 PM   #4
peranders's Avatar
The servo opamp will feed back audio signals up to 500 Hz to 1 kHz. So it must be good in those frequenies which most decent opamps are. Over 100 Hz a very small part of the audio signal goes through the servo. As Thomas says almost any opamp will fit. Personally I chosen an AD8620 (or OPA2134) as a buffer + servo and for the servo part it's massive overkill but it's nice with 80 uV offset! You can see my implementaion of AN-1192 at my homepage.
Old 20th November 2006, 07:30 PM   #5
Thank you for your answer. That was what I thougt. And today I found some LF411 and LF412 stuffed away at my work. But they where labeled only CN, not ACN. But what I can see from the datasheet its only V-rating that difference from the ACN-version... I will try them first.
But I have a new question. How do I do with the mute-part of the LM886. Do i need mute-resistors and cap's for every LM3886, or do I need only one to mute them all?
Old 20th November 2006, 08:00 PM   #6
peranders's Avatar
The mute resistor is very important. No resistor = MUTE.
10k is a normal value but I did chose 33k + 100 uF just because I wanted a longer delay _with_ a 100 uF cap. If you don't want the delay, just omit the capacitor but it may be a good idea to have it since you have a DC servo which may create a small startup transient. Please check the datasheet and the diagram over this mute resistor. You should have more than 0.5 mA from that pin.
Old 20th November 2006, 09:03 PM   #7
BrianDonegan's Avatar
Interesting post on the mute resistor:
http://www.diyaudio.com/forums/showt...710#post845710
Try a 4k7.
Also, we are using the LF411CN with great results.
Twisted Pear Audio
Old 21st November 2006, 03:16 PM   #8
peranders's Avatar
Notice also my comment there about the measurements.
scratch BPA200 pcb lay out digi01 Chip Amps 63 21st December 2007 07:51 PM
Bpa200 Lm3886 zlast Chip Amps 9 7th July 2007 04:27 AM
Bpa200 Opa549 Sub Amp Gcollier Chip Amps 8 2nd October 2006 11:58 PM
Bpa200 enter Chip Amps 2 3rd January 2006 08:16 PM
My BPA200 PCB Dxvideo Chip Amps 14 11th December 2003 07:25 AM
Page generated in 0.19683 seconds (46.56% PHP - 53.44% MySQL) with 10 queries
