Old 17th November 2006, 01:22 AM   #1
Keyoke is offline Keyoke  United States
Default enclosures..
So where's a good place to pickup enclosures? I know about par-metal and thlaudio.com.. I actually like some of the stuff that's at thlaudio, but I don't want to deal with the overseas ordering..
Anyplace local to the US that makes a decent enclosure? I thought about the hammond enclosures, but I'm not sure if they have the removable face-plate.. drilling the plate while it's already on the chassis isn't something I really want to deal with.
Ideally, I'd be able to have someone like 'front panel express' (http://www.frontpanelexpress.com/) make the front/back panels..
Thoughts?
Old 17th November 2006, 05:57 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
I don't think a chipamp, is worth that expense...
Old 17th November 2006, 06:15 AM   #3
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
I do believe that the expense is worth it, if the end result is exactly what you want then cost is not such a major factor.
Any Hammond chassis I have used has had a removable front and back plate. Also check out ATI .
Old 17th November 2006, 11:52 AM   #4
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Keyoke:
I built four gainclones in enclosures supplied by Horace Atkinson at iagaudio.com. I mapped out the holes that needed to be drilled (3 of various sizes on the front panel and far more on the rear) and sent him a diagram. The cost to have him do it was minimal -- quite a bargain, in fact.
Incidentally, his chassis are exceptional-looking and very well built. The photos on the website don't do them justice.
Scott
Old 17th November 2006, 02:53 PM   #5
Nordic's Avatar
Some nice stuff there Scott, Although I'm a firm believer a case should not cost more than its contents...
I love that chromed base for a valve amp.
Old 17th November 2006, 04:34 PM   #6
lgreen is offline lgreen  United States
lgreen's Avatar
Default my recommendation
I recommend either-
(a) par-metal ("Antek" on ebay sells them too)
(b) getting a broken or cheap hifi item on EBay and having frontpanelexpress create front and/or rear panels for you. You can discard the originals and no one will know that the case is a denon/pioneer/ whatever. My Gainclone is acually a Kyocera CD player with a new front panel. That said make sure you can flush mount a front panel on the old component, some are easier than others in how to do this. You can use black spraypaint like rust-o-leaum to "erase" the prior back panel if you want.
My DIY audio projects- PartTimeProjects.com.
Old 17th November 2006, 05:31 PM   #7
Nordic's Avatar
Its pretty easy to apply a wood veneer over an old amp's face, and to spray the rest matt black...
Old 17th November 2006, 05:54 PM   #8
phn is offline phn  Sweden
phn's Avatar
I don't understand that reasoning at all. Lots of tube amps aren't worth the additional cost of potted transformers, yet people buy hem all the time.
That puts the T amp crowd in a very tight spot.
I think you shouldn't spend more than 10 pct of what you paid for your speakers on the amp. While I firmly believe that, it just doesn't work in practice. I sold a pair of speakers costing 3-4 times as much as the ones I have now. By that logic I should sell my current amp and by one costing 1/3 of the price.
You should buy and spend whatever you want. No more, no less.
Old 17th November 2006, 06:15 PM   #9
falcott's Avatar
I found this old 1960s-70s hi fi tuner on the roadside and gutted it. My VBIGC is being built into it right now. The front panel will be replaced with a piece of etched aluminium, and the battered veneered sides have been replaced with solid pieces of rosewood. It should end up to be a cool looking retro-inspired amp (I'm hoping )
"Everything should be made as simple as possible, but not simpler." - Einstein
Old 17th November 2006, 08:30 PM   #10
lgreen's Avatar
Very nice, its going to need some vent holes for cooling...good luck with that!
need help with first sub enclosures NallaN Subwoofers 4 20th January 2008 06:08 PM
new enclosures for 105.2 qguy Multi-Way 0 14th March 2005 07:18 AM
WTB enclosures Mark Hathaway Swap Meet 1 30th March 2003 10:35 AM
X-amp enclosures? FullThrottleRic Pass Labs 1 12th February 2003 04:41 PM
Page generated in 0.16548 seconds (58.21% PHP - 41.79% MySQL) with 11 queries
