| Chip Amps Amplifiers based on integrated circuits |
I've made a few amps with LM3886T. They can be seen at: http://www.circuit.lt/?section=sch&page=lm3886t (sorry, only in Lithuanian, but you can still understand images )In photo is older revision. They work fine for me, but few visitors have reported, that their amplifiers are humming. For others - fine too. Why could this happen? Is there anything wrong in PCB? Regards, circuit |
#2 | |
Could you post the revised schematics? |
#3 |
Your circuit looks fine.
Humming possibly caused by power wires/transformer badly positioned in case. Also builders should make sure the input and output jacks are isolated from the case. braid power cables and use shielded signal cables inside the box, or twist a pair of cables tightly if you don't have shielded cable. Keep cable between input jack and pcb as short as possible... |
#4 |
| 10 pcs LM3886T | daedalus | Swap Meet | 3 | 28th March 2009 03:39 AM |
| Wtb :- LM3886T PCB | poynton | Swap Meet | 7 | 6th September 2007 04:18 AM |
| Lm3886t / Lm3886tf ? | matt09 | Chip Amps | 8 | 9th August 2006 01:38 AM |
| Lm3886t | Nobodysfool | Chip Amps | 10 | 22nd May 2006 06:26 AM |
| trying to post board lm3886t | psychosteve | Chip Amps | 12 | 23rd November 2004 12:43 PM |
| Page generated in 0.09846 seconds (67.28% PHP - 32.72% MySQL) with 10 queries |
