| Chip Amps Amplifiers based on integrated circuits |
I'm looking for P2P wiring guides for the LM3886 and LM3876. So far I have only been able to find a Point to Point, step by step wiring guide for the LM4780 here: (Mind Boggling that it's even possible)
http://www.mhennessy2.f9.co.uk/micro...nstruction.htm I'm looking for something similar for these other two chips. I know they must be much simpler then the Stereo chip, but I don't really want to re-invent the wheel since I know these chips have been P2P'd many, many times before. |
#2 |
#3 |
Why can"t you just look at the LM3886 schematic and simply wire it up P2P or on Perfboard?? Seems that you don"t really need a wireing guide as there are only a few components so the P2P wireing would be extremely simple.....
I actually just designed a PCB and etched the PCB for a LM3886 Power amp and drilled and stuffed it in just a couple hours yesterday so I"m sure you could figure out the P2P from the schematic in a fraction of the time..... In case you decide to go the PCB route you can use this one which i just did.... Cheers PS: They should be actual size and the traces are as Big as I could make them...The Bottom pic is right 90degrees to the top pic.... |
#4 |
Actually I was hoping to wire them up with Rat Shack Perf Board, I even had the layout all nicely planned! But when my chips arrived yesterday I discovered that the spacing is all out of whack and the pins dont line up with the holes! So I thought I would look into the idea of doing P2P. I will have to look around for some suitable perf board to see there is any... If not then maybe I will etch my own board or P2P. I havn't made a final decision yet.
I do have a copy of Eagle and have done a couple simple bords for other projects. If you layed out that board in Eagle it'd be great if you could share your files. |
#5 |
Hi, I actually don"t use Eagle as I think the Free version has a Component or Size limit and many of my Boards are much larger than there size limit....
The program I used was Express PCB, the Pin spaceing shuld be correct in the PCB Layout that i posted for the LM3886 Chip and if printed out at 100% it should be the correct size.... I actually have never been able to get the Spaceing 100% perfect for the LM3866 but it is good enough so that all Pins fit without haveing to bend any Pins to much..... This is the second Chip amp I have had to build in the last week as my first one was riddled with problems...I was useing the Chipamp as the power amp stage for my Guitar amp and I just couldn"t get it working properly so I decided to start from scratch and redesign the whole thing but this Time I am useing a Discrete J-Fet preamp stage based on a fender preamp and on a seperate board from the power amp stage and seperate from the distortion circuit, this way if one circuit has a problem I don"t have to scrap the whole amp like I did before and If I want to add a different guitar effect I can install the Circuit easilly.... well good luck.... Cheers |
#6 | |
#7 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#8 |
OMG! It's True! I have an LM3876 sitting on Rat Shack Perf right now! The holes are even large enough!
#9 |
This (from another poster) is what inspired me. About as simple as you can get. For the LM3886, just add the mute resistor.
I've made several. Some even look this nice. Takes about an hour.
Poor stereo mix? Switch to mono! Perfect. |
#10 | |
What RS board are you using? Be sure to take some pictures. I have a 500VA torroid and chips looking for some action! I just need motivation. What were you planning to do for the enclosure? Cheers, Gio.
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
| Step-by-step ambitious first project! Suggestions? | ledhed2222 | Multi-Way | 7 | 13th August 2009 03:51 AM |
| Step-by-step guide to building a speaker | Richy | Multi-Way | 5 | 5th August 2008 12:48 AM |
| hypex UcD400 step by step | MA_AV | Class D | 16 | 16th June 2008 11:01 PM |
| stuffing Mileva: first timer step by step questions | schro20 | Full Range | 7 | 2nd June 2008 05:49 PM |
| how to make spherical wood horns, step by step | angeloitacare | Multi-Way | 0 | 29th May 2007 01:50 AM |
| Page generated in 0.14662 seconds (68.71% PHP - 31.29% MySQL) with 11 queries |
