Smoking Chipamp Smoking Chipamp - Page 2 - diyAudio
Smoking Chipamp
Smoking Chipamp
Old 10th November 2006, 06:41 AM   #11
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Smoking Chipamp
Do you have any fuses? If yes, which values?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 10th November 2006, 07:23 AM   #12
Lucas_G is offline Lucas_G  Netherlands
Hi Peranders,
I don't have any fuses other than at the iec 230Volt inlet.
I know that some people like to add fuses at their DC rails, and maybe it would have been a life saver for my LM3886 chip, but I also know that many people think they are too slow to be a lifesaver for chips... Do you think I should add one?
Today I disconnected the PSU and Amp board and measured the voltages on the particular PSU that was connected with the blown LM3886. I measured 25 AC and 33 DC on the rails. Polarities were all OK.
So it remains a mystery to me. I doublechecked all soldering points, values etc.
There remain two possibilities:
1. Might it still be oscillations that killed the chip so fast? I did not install the feedback capacitor, only the feedback resistor (22,1K) and its loop is a bit long-legged...
2. Are there any fake LM3886 around? I bought these from some source in Asia (don't remember which) and it is labelled PM14BV above the LM3886TF inscription. Or did I just catch a faulty one?
If I do not find the clue to this, I guess I will have to try the second ampboard and see whether it will smoke too. If I would insert fuses, what values would do?
Lucas
P.S. I hope BrianGT or Peter Daniel might look into this, since both must have a lot of experience with these pcbs and LM3886 chips...
Old 10th November 2006, 07:40 AM   #13
sayang001 is offline sayang001  Netherlands
Can you make a clear picture of the front of the chip. I have experience with fake transistors from Asia ....
http://www.sayang.demon.nl/projects/sanken/sanken.html
I have some real (directly from National) LM3886TF as well to compare yours with.
http://www.sayang.demon.nl/projects/.../kimberly.html
Use small 24V 2w bulbs in series with + and - rails, in case of high current these will light up and limit the current. LM3886 with no load will not light the bulbs. I used this when testing with Kimberly her amplifier.
Old 10th November 2006, 08:30 AM   #14
Hi Sayang,
I cannot come that close wityh my camera to the chipamp.
I enclose one photo from above and one made with my scanner of the backside of the chip where one can see the damage.
Lucas
Old 10th November 2006, 08:33 AM   #15
Picture of backside of LM3886
Old 10th November 2006, 08:48 AM   #16
Desolder the chip from the pcb and put it on the scanner with it's front, it is broken anyway
Old 10th November 2006, 12:59 PM   #17
MikeB is offline MikeB  Germany
MikeB's Avatar
OMG, i am not familiar with the board, but it looks like you skipped the dc-blocking cap instead of shorting it. This makes the amp unity gain and oscillate like hell.
Why do you simply skip parts ?
Mike
Old 10th November 2006, 01:56 PM   #18
You are right. I will do this this evening...
Old 10th November 2006, 01:58 PM   #19
Mike
Hi Mike,
The reason can be found here:
I opted for the standard configuration with just R3 (680 Ohm) and no Ci (47 uF) feedback capacitor as described on page 8 of this pdf: http://www.chipamp.com/docs/lm3886-manual.pdf
I checked the pcb. The 22,1 kOhm resistor is connected!
Lucas
Old 10th November 2006, 02:17 PM   #20
MikeB's Avatar
Hi Mike,
Lucas
Sorry Lucas, my fault. I should not post not knowing the pcb...
But, you might check the soldering next to r3, the "SG" point. It looks like the pad on the bottom is broken. In this case you would get the same result, oscillation.
It just looks suspect on the photo...
Mike
Smoking ChipampHide this!Advertise here!
Zen V4 Smoking Q5 Diomedian Pass Labs 6 15th November 2005 02:46 PM
amp smoking biznatcher Car Audio 5 13th September 2004 11:48 PM
Smoking Amp jkramer Solid State 15 28th August 2004 04:17 PM
DOZ smoking? Kari Solid State 8 1st February 2004 02:40 PM
Copyright ©1999-2017 diyAudio
