| Chip Amps Amplifiers based on integrated circuits |
I'm trying to get the parts together to build a Gainclone amp. Have the caps and resistors already, but I need the transformer and the Nat Semi LM3875TF. No luck finding a brick and mortar store yet in the Los Angeles area with this items.
Any ideas out there? I've asked the people at a couple of electronic parts stores but they don't know of any places. Thanks for the help. |
#2 |
#3 |
Who sells Bicron toroidals? They make plain vanilla 60hz toroidals.
#4 |
Jduffy,
I live in the O.C. and have the parts you are looking for. I am not a merchant, just have extras. They are new and were purchased from reputable companies. If you are interested just send me an e-mail. |
#5 |
Sorry but I can't send email because I'm a new member. I have to wait until I have X number of posts first.
Thanks for the offer though. |
#6 |
The fellow who sells torroids on EBay is worth a visit -- AnTek -- these are stepper motor/CNC toroids -- obviously from China and obviously "very strong stuff" -- put toroid in the EBay search engine. Bringing transformers from New Jersey to California is like coals to newcastle, however. AnTek also sells nice aluminum and steel cases.
As a newbie, I would try to dissuade you from using the TF version of the LM3875 or LM3886 -- reason being that the insulation is a real heat barrier. While the insulation makes it more convenient to use, the thermal impedance is something like 1 degree C/ watt. This translates to a whoppingly bigger heat sink for the same amount of power dissipation. I have found no difference between the T and TF versions when listening (but others have differing opinions.) Try using the mica insulator vresion with silicon grease on each side -- you can use pretty high mounting pressure with these two chips. (something you can't do with the LM4780.) |
#7 |
Digikey sells some waxy stuff that is supposedly superior to grease...Ultrastick? Sounds pretty groovy...
http://rocky.digikey.com/WebLib/Aavi...Ultrastick.pdf |
#8 |
A guy hooked me up with a nice transformer and a couple of the LM3875s. I went with the insulated variety but not a problem cooling. I was an overclocker back in the day and have plenty of heatsinks. It took a couple of hours to build but no major hassles. It was crazy simple wiring it up. Not a bad sounding amp, particularly when you figure it cost me about $65 and I had fun building it. Best part is that I can keep tweaking the thing when I get bored with it. Good times! |
#9 | |
Just curious, but why not use computer-grade thermal paste, like Arctic Silver? Computer overclockers swear by the stuff, and with heavy thermal loads (like a power amplifier or Prescott), it's been show to drop the temperature by a few degrees. |
#10 |
How 'bout these little nifty copper heatsinks? Would they add much cooling to the print side of an LM3875?
http://www.thermaltakeusa.com/2005/c...ry/ramsink.htm |
| FS: Toroidal Transformers | BobG | Swap Meet | 2 | 25th August 2009 07:00 AM |
| Toroidal transformers | scottw | Power Supplies | 19 | 17th November 2006 10:09 AM |
| Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) | Rixsta | Pass Labs | 10 | 23rd April 2004 03:41 AM |
| Page generated in 0.15847 seconds (55.55% PHP - 44.45% MySQL) with 10 queries |
