| Chip Amps Amplifiers based on integrated circuits |
My latest attempt at a LM3875 chip-amp still won't work. You can see pictures below. (I'll add the PCB design and notations later.)
Can anyone tell me how I screwed up? |
#2 |
Pic #2:
#3 |
Really hard to tell but I believe you should try to improve your solder skills.
![]() If the supply voltages are correct, measure every trace with an ohmmeter to make sure everything is conducting the way it should. /Hugo |
#4 | |
I should also probbably get a better soldering iron tip. Or a better soldering iron. (The crappy PCB does'nt much help, either.) |
#5 |
Yes, a good soldering iron is a Diy-er's best friend. You invest once, you have lifetime pleasure.
![]() /Hugo |
#6 |
Just remember if you are measuring the traces with an ohm meter MAKE SURE THE POWER IS OFF!!!!!!!!
#7 |
Good point; and caps discharged.
/Hugo |
#8 |
Am I wrong or is one of them two larger electrolites connected the wrong way'round?
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#9 |
And?
#10 |
it would have been faster to p2p it
| chipamp.com has been off for a while ???? | A Sanchez | Vendor's Bazaar | 0 | 17th April 2008 06:40 PM |
| chipamp ccs | elmar | Pass Labs | 0 | 14th December 2006 04:04 PM |
| FS chipamp and dac | eapavant | Swap Meet | 16 | 3rd August 2006 05:10 PM |
| Will this transformer work with the ChipAmp kit? | Spasticteapot | Chip Amps | 8 | 18th January 2006 10:58 AM |
| Aargh somebody help me remember this cabinet | cdwitmer | Multi-Way | 6 | 9th July 2003 03:35 AM |
| Page generated in 0.12139 seconds (71.43% PHP - 28.57% MySQL) with 11 queries |
