Old 26th October 2006, 03:36 PM   #1
cibi is offline cibi  Italy
Default TDA2050 as "false stereo" amplifier
HI everybody,
I am making a simple amplifier with TDA2050. The particoularity is
that i want my amplifier to mix together left and right channel of
the source, so to amplify them togrther.
To mix source channel i use a regoular dual opamp, each channel in
non inverting configuration, then I use TDA2050 in inverting
configuration, (as a simple mixer). (See picture in attachment).
Practically i split the 22uF-680ohm branch from inverting input to
ground of classical configuration into two branches with such values
to make things equivalent.
The matter is that the configuration doesn't seem to be stable.
Does anyone know why? Has anyone got any possible idea to reach my
intent in a different way?
Thank you very much.
Old 26th October 2006, 04:01 PM   #2
You don't need the op-amps. Connect the TDA2050 in shunt
feedback mode with two input resistors, one for each channel.
/sreten.
Old 27th October 2006, 08:17 AM   #3
OK, sreten, I will try, but the reason for the two opamps is the following: without the opamps, the 1 meter cable I use becomes part of the negative feedback net. Its parasitic components may bring to low stability; my fear is that it may oscillate or couple with external signals.
I will let you know.
Tahnks, Cibi
Old 27th October 2006, 08:25 AM   #4
Did it Himself
richie00boy's Avatar
Are you using a split or single supply? As you have DC coupled speaker I assume split supply, so then why are you biasing the TDA non-inverting input not at ground? Also your op-amps have no DC reference on their non-inverting inputs, and they are driving too low an impedance, they don't like to see less than 2k.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 27th October 2006, 11:17 AM   #5
OK, richie00boy, you're right. The picture i posted is just a draft made with paint to show the principle.
I use a 12V single power supply. It comes from a PC silver box (so it's switching). The speaker has a 1000 uF decoupling capacitor, (not present in the schematic), and the opamps have a 100K - 100K partition in non inverting input for DC polarization and a 10uF capacitor for signal coupling.
Is all this important?
Thank you, Angelo
Old 27th October 2006, 11:43 AM   #6
Did it Himself
OK that sounds alright. Can you better describe what instability you are experiencing?
Old 27th October 2006, 02:09 PM   #7
1. I have much more noise than I have with the "normal" single side configuration, (that I also built myself);
2. The speaker makes something like "shots" with a frequency of about once per second.
Old 27th October 2006, 02:27 PM   #8
Did it Himself
Have you tried a 12V car battery instead of SMPS to see if it still does it?
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
distorted & hiss sound after "add aux-in" to my old car stereo reko Car Audio 2 2nd March 2008 03:49 PM
Is this a wacky idea? "Portable" Stereo... jjdche Multi-Way 6 16th May 2004 07:00 AM
Schematics for "NAD Stereo Receiver 7130" tobias_svensk Solid State 1 24th March 2004 04:51 PM
WTB: stereo potentiometer ALPS "black beauty" or... kasra Swap Meet 8 10th October 2002 06:54 PM
Page generated in 0.10714 seconds (72.95% PHP - 27.05% MySQL) with 11 queries
