| Chip Amps Amplifiers based on integrated circuits |
I'm prototyping a TDA2050 amplifier, when I turn it on everything is fine, dead quiet and no oscillations, but after 5 minutes a hum appears on the speaker.
I did everything that I now to kill the problem, but it don't go away. It disappears only when I shut down the amplifier and still playing with the capacitors charge. Anyone can help me? Please, this is really giving me a headache. The attachment have the amplifier and psu pcb layout. |
#2 |
What's the size of the heatsink???
#3 |
Hi Diegot,
Are you sure you don't have one of the electrolytic caps in backwards. Is the amp hot when the hum sets in? Possibly a cold joint that changes as the lead heats up... It's definitely either loading down the supply or the filtering is becoming ineffective over time, because the hum goes away when the ac is pulled yet the amp still plays. From your pictures it looks like you have a few supply caps paralleled. You have a number of clues to help , Good luck. Regards, Mike.
"We are all agreed that your theory is crazy. The question which divides us is whether it is crazy enough to have a chance of being correct. " Niels Bohr |
#4 | |
Leolabs wrote
Gajanan Phadte |
#5 |
Leolabs, the heatsink have 6 x 6 cm, it was from a old AT power supply, but it's only a temporary one.
Mike, thank you very much for your tips, the problem is really related to the power supply. I took the power supply of the first chipamp I had made and plug it in the new one. Everything is fine now, but I cannot use this old supply, so I will fix the new one, maybe the caps that I bought are failling. Gajanan, thanks for your reply, but I'm here to get some help not a joke. Regards Diego |
#6 | |
The clue here is that the hum builds up overtime. This sounds like a leakage path that gets worse as it heats up. I don't know if you've had it on long enough for one of the caps to appear warmer than the others. Good luck getting to the bottom of it. Regards Mike.
#7 | |
Gajanan Phadte. |
#8 |
Finally I discovered the source of the problem. It's related to the transformer. The PSU caps and the amplifier layout are OK.
My transformer is a 20+20V 240VA unit, when the amplifier get warm the PSRR decreases and the hum appear. I plugged a 12+12V transformer and the problem doesn't occur. I believe that this occur because of the idle voltage of the power supply, higher than the maximum voltage specificated at the datasheet. It's a behavior of the TDA2050 that I wasn't expectating. |
#9 |
If u had exceeded the absolute max ratings of the IC, then better u replace the IC with a new one as it may not work to specs.
Gajanan Phadte |
#10 |
four points I see on the PCB. 1. the input cap shows an axial electrolytic. The space looks ideal for a large polypropylene or polyethylene metallised film type. Aim for a good RC time constant to match your NFB time constant and PSU time constant. A value between 1uF and 10uF could fit. Is there a DC bias on the electrolytic? 2. the internal link between the input ground and the power ground should be removed. Instead take the input ground from a new connection right beside the RCA grounding point to the Central Star Ground. You may want to try fitting a 10r resistor into the space left by removing the link. 3. the NFB cap looks quite small. What RC time constant is there? 4. is there a resistor preceding the RF capacitor on the input?
regards Andrew T. |
| Subwoofer Humming problem | Vandergraaff27 | Subwoofers | 49 | 1st May 2010 09:21 PM |
| Guitar Pre amp humming problem | ali_moinuddin | Pass Labs | 1 | 6th July 2009 04:31 PM |
| Guitar Pre amp humming problem | ali_moinuddin | Pass Labs | 0 | 6th July 2009 04:17 PM |
| Humming Noise, Problem? | MorePower7701 | Solid State | 2 | 26th December 2007 05:49 AM |
| LM3886 humming problem | Niila | Chip Amps | 20 | 13th March 2007 09:17 PM |
| Page generated in 0.13134 seconds (69.66% PHP - 30.34% MySQL) with 11 queries |
