| Chip Amps Amplifiers based on integrated circuits |
Hey maybe you guys could help me out here.
I just installed a dc trigger ssr in my chip amp but it makes my transformers buzz badly, when I remove the ssr,of course it goes away. It is a CRYDOM SOLID-STATE RELAY D2440-10 dc controlled(3-32vdc, rated to 240v / 40 amps. My trannys are 2x 400va dual 25v. (The relay is in series with the power in to the trannies.) Is the ssr faulty or should I get a mechanical type? Just a note, I tried it out on my shop radio and I didn't seem to get any buzz.
Yes! Its cold in Cold Lake... |
#2 |
Solid state relays can be sensitive to DC components on the AC line, most newer ssr that are optically isolated do not have this problem.
If the ssr is creating a triggered DC component via its internal switching your chip amp could be very sensitive to this depending on construction, bypassing ect.... I would check another ssr then try a standard relay. |
#3 |
Okay, I guess I am understanding. Since the ac going through the ssr isn't pure due to the internal switch of the ssr.
I will probably go and get a mechanical type, although the town I live in doesn't have to much on the electronics front...back to the internet for buying.
| what is a chip amp? | cadbury8 | Chip Amps | 27 | 7th July 2007 08:01 AM |
| Clarion car stereo problem - bad Sanyo LA4743B chip? | GirchyGirchy | Chip Amps | 4 | 22nd August 2005 06:41 AM |
| STK413-20 amp chip problem | johnsciolino | Class D | 0 | 18th October 2004 11:22 PM |
| What chip should I use? | soundNERD | Chip Amps | 5 | 30th September 2004 03:57 AM |
| New DSD D/A chip | SteveG | Digital Source | 0 | 27th August 2002 06:16 PM |
