Old 23rd October 2006, 10:10 PM   #1
diegot's Avatar
Default TDA2050 Oscillating
I'm prototyping a board for the TDA2050, but it has a buzz at the output and if I touch the potentiometer at a certain position I can hear a local radio playing at the speaker.
For now I'm using 100n ceramic paralleled with the 220u caps. When done, I will use polyester ones. The resistor and the cap paralelled with the 22k resistor(feedback) are not present and I don't have the 220p cap in the input to ground.
I'm using the components values suggested in the datasheet and the PCB it's based on the layout presented in the datasheet, too.
There is something wrong with my layout?
Old 23rd October 2006, 10:11 PM   #2
diegot's Avatar
Default Schematic
Here is the schematic that I'm using.
Old 23rd October 2006, 10:14 PM   #3
diegot's Avatar
The amplifier assembled
Old 23rd October 2006, 11:12 PM   #4
pinkmouse's Avatar
Stick a 0.01uf across the input + and -.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 24th October 2006, 04:10 AM   #5
sivan_and's Avatar
Send a message via Yahoo to sivan_and
diegot !!!
It is NORMAL..that BUZZZing sound when u touch the inputs...I don't thing u need to worry abt that....unless u always keep your fingers on the input pins :-)
SivanandBalan
Old 24th October 2006, 04:11 AM   #6
sivan_and's Avatar
diegot !!!
SivanandBalan
Old 24th October 2006, 02:08 PM   #7
diegot's Avatar
sivan_and
it's not about the buzz when touching the input, but it is always present.
I put a 150p cap before the 1k res going to ground, and the oscilations apears to went away. For now I a have a few problems that I believe it's relationed with the power supply, because some falls caused by a shot-circuit, my fault.
I still want to know what you thing about my layout.
Old 25th October 2006, 05:49 AM   #8
sivan_and's Avatar
I didn't find any problem with the layout....Check the resistor values in the gain setting...might've used wrong values..resulting in very high gain and oscillations !!
SivanandBalan
Old 25th October 2006, 06:06 AM   #9
sivan_and's Avatar
SivanandBalan
TDA2050 vs LM3886 Wynand Chip Amps 5 7th September 2009 05:49 AM
Tda2050 Jpoole908 Vendor's Bazaar 0 1st June 2008 06:34 PM
Tda2050 Mr. Triatic Solid State 8 26th April 2004 06:00 PM
Page generated in 0.11065 seconds (68.37% PHP - 31.63% MySQL) with 11 queries
