| Chip Amps Amplifiers based on integrated circuits |
Hi all!
I'm still very new to this stuff. I built a CMoy headphone amp thanks to this excellent tutorial and had a lot of fun with the project, so I've decided to bite off more than I can chew and start a project like this. It's also the first time I've dealt with AC voltages outside of a circuit analysis lab at school, so I'm doing lots of research and will be asking plenty of questions before I break out the soldering iron. I've ordered the LM4780 PCB from AudioSector.com (looks great!) and have slowly been sourcing some parts. My intention is to have one chip (in parallel configuration) per channel, both in one chassis, and I'd like to keep the dual-mono design right down to the transformers. I may also include a stepped attenuator. We'll see. The amplifier sections shouldn't be too difficult to build thanks to Peter Daniel's excellent work, but I'm a little uncertain about the power supply so I'll post up what I had in mind for comments and criticism, as I'd like to put off any serious cases of death. ![]() Salient issues (so far): 1) I'm a little uncertain about fuse placement in the circuit. I read that they should be slow-blow and 3.15A for 115/120V mains. I think I may have them on the wrong wire now that I look at the schematic. 2) The recommended transformer rating is 300VA, 22V+22V for one chip; will I have trouble using two for two chips, wired in parallel with the mains? I'm thinking of going with Plitron Standard series trafos. 3) The recommendation for the rectifier diodes is the MUR860; Digikey only seems to stock the lead-free variant, the MUR860G. Will this cause problems / sound quality deterioration? 4) The 1000uF caps will likely be 50V Black Gates. Apparently there's no need for snubberizerationification (or whatever the technical term is). ![]() Please go ahead and tear this apart so's I don't blow myself up! ![]() -A |
#2 |
hi gongzero,
I would normally only use a single fuse in the active/live AC wire. The rating would have to be changed accordingly. You can get an IEC chassis male socket with a fuse holder built in. This will simplify the construction process and reduce the chance of an wiring error. regards
Greg Erskine |
#3 |
Why dont you just get the parts kit for the board from Peter?
I have built 3 dual mono kits from him and the parts he supplies is great stuff. Dominick
A real amateur enthusiast! |
#4 | ||
![]() Quote:
Mostly the issue was myself being a poor student and only being able to buy parts $30-40 at a time. ![]() I am using his application notes to guide my purchases, though. -A |
| 43v SMPS for dual bridge mono LM4780 | juan_caliente | Chip Amps | 45 | 2nd May 2010 11:37 PM |
| LM4780 dual mono -- boards | jackinnj | Swap Meet | 1 | 1st October 2008 01:44 AM |
| AudioSector LM3875 dual mono classic kit. | gychang | Swap Meet | 2 | 2nd August 2008 02:28 PM |
| AudioSector LM3875 dual mono premium kit. | nodiak | Swap Meet | 1 | 16th October 2007 06:38 PM |
| lm4780 Dual mono kit from audiosector? | Nickzz | Chip Amps | 2 | 10th March 2006 02:32 AM |
| Page generated in 0.08900 seconds (72.13% PHP - 27.87% MySQL) with 10 queries |
