diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Preamp hum problem somehow related to inputs (http://www.diyaudio.com/forums/chip-amps/88699-preamp-hum-somehow-related-inputs.html)
arjscott 21st October 2006 12:20 AM
Hi all,
I recent bought a preassembled Twisted Pear Kookaburra preamp from a friend and have just finished putting it in an enclosure.
It sounds fantastic and puts my current consumer hi-fi integrated amplifier to shame, even with the problem I've encountered.
I have to say I have very little knowledge of electronics, but you have to start somewhere, right?
Anyway, the problem is, at high volume a rather loud hum appears to be generated and can be heard from the speakers.
I found if I wave my fingers near the input RCA or cable it affects the sound of the hum significantly. And, if I place my finger over the end of the RCA, the hum stops.
Does anyone know what the problem is, and if so, how can I solve it?
Thanks in advance.
Andrew.
v-bro 21st October 2006 12:36 AM
Seems like there's a ground problem, how does it sound with the input unplugged?
Leolabs 21st October 2006 01:07 AM
Maybe bad contact regarding ground wire.
Minion 21st October 2006 02:15 AM
Yes, It sounds like the Ground (Maybe the ground on the RCA inputs/Outputs) as loose or not connected....
Try tieing the ground wire from the RCA to Ground....
arjscott 21st October 2006 07:06 AM
Thanks for the replies. Quite right - it seems one of the inputs was not gounded properly.
It seems so simple now :-)
Andrew.
Resources saved on this page: MySQL 18.75%
