How to wire vol control pots to chipamp?
Old 19th October 2006, 10:00 PM   #1
ransom peek is offline ransom peek  United States
Default How to wire vol control pots to chipamp?
I would like to use my Briangt LM3875 gainclone with a Marantz CD5001 CD player that has no volume control.
I understand I need to be sure the two sides are relatively close in terms of resistance at any particular point for proper balance.
QUESTION: What is a recomended value - I have 3 dual pots to choose from, I believe all are logarithmic - 10K, 25K, 50K, or 100K?
QUESTION: How are these to be wired in the case of the chipamp? IN SERIES? Do I route CD player signal 1 to the center of POT SECTION 1, then another terminal of POT SECTION 1 to the amp? In effect, then, the variable pot resistance value just goes in series between the CD Player input signal and the amp input.
Then same for input line 2 using the second section of the dual pot?
Old 19th October 2006, 10:37 PM   #2
kmj is offline kmj  Sweden
kmj's Avatar
Try the 10K or the 25K
You wire them in series with the source (or inputseletor in case of multiple inputs.)
The pots I've used have had 3 pins on each side (input, output and ground) and you wire them in this order. Now, mind that tere are different types but on the one I have the input is at the far left, output in the middle and ground to the right, this if the pins are upward and you want to raise volume by turning the knob clockwise.
Each channel in situated in a row.
On the pot below (alps) it is from the left (or the pin farthest away:
ground, output, input.
Edit:
forgot picture
.....Where the music comes to die.
Old 19th October 2006, 11:20 PM   #3
If I use the 25K pot, you are saying that each of the two inputs (center of each RCA jack) ties to the chipamp star ground through the 25K path in a pot. The center tap of the pot ties to the input of the chipamp.
Is this logic correct? Is this schematic correct?
Old 20th October 2006, 03:40 AM   #4
DoomPixie is offline DoomPixie  Wales
Send a message via MSN to DoomPixie
yup.. thats the shizzle
Old 21st October 2006, 01:00 AM   #5
Wait! There is an old thread in this forum that advises to ground the third pot leads to the signal ground, not the star ground...
Which is correct?
I think the signal ground makes more sense...
Old 21st October 2006, 08:37 AM   #6
Nordic is offline Nordic  South Africa
Nordic's Avatar
He is probably refering to the signal groundstar SGS.
Old 21st October 2006, 04:31 PM   #7
What is a signal groundstar sgs?
Does the attenuator pot get wired to the rca jack grounds (signal ground) or star ground?
Old 21st October 2006, 05:45 PM   #8
Nordic's Avatar
Erm thats "normaly" formed on the ground tab of the RCA input...
Old 21st October 2006, 06:11 PM   #9
what is "erm"?
Old 21st October 2006, 06:53 PM   #10
Nordic's Avatar
Lol, now your going to ask me what lol is... it is, erm, of no concequence....
How to wire vol control pots to chipamp?Hide this!Advertise here!
Remote Volume Control + Extra board + Alps Motorized Pots jamesjung21 Swap Meet 12 23rd November 2006 10:03 PM
Is shielded wire necessary for chipamp inputs? ransom peek Chip Amps 16 6th June 2006 08:33 PM
balance/tonal control pots Doovieman Parts 0 9th July 2004 07:15 PM
Wire wound pots as volume control ???? Shoog Everything Else 4 29th April 2004 06:09 PM
control the 50k alps pots sma Everything Else 1 17th December 2003 06:13 PM
Copyright ©1999-2017 diyAudio
