| Chip Amps Amplifiers based on integrated circuits |
Hi, I have a Brian GT 3875 amp that I have been running with a dual secondary torroid on my work bench for about 1 year. Well the torroid had to go into another project so I am having to use a center-tapped transformer of questionable design that I had laying around. I've changed the power supply as per the instructions(Jumpers between diodes as pictured in the assembly manual) and when no load(amp boards)are connected I get a good 19.5 both - and +. However when I connect the amp boards the V+ stays at 19.5 V but the V- dropes to - 16.5. The DC offset becomes high at .5V also. These same amp boards when connected with the dual secondary torroid had DC offsets less than 10mv. Suggestions appreciated.
#2 |
The centertap of the transformer - did you put that to GND?
Best regards Bo |
#3 |
I have the centertap connected to the PG+ of the rectifier board which is also effectively PG- due to the jumper on the board. I then run wires from PG- of the rectifier board to the PG- connection of both amp boards. There is no reason to run the PG+ wires to the amp boards correct?(same potential as PG-)
#4 |
sounds like you have inadvertently made another change. Have another look and try to identify the changes before to after.
regards Andrew T. |
#5 |
Aren't the rectifier diodes set up diffirently on Brians boards depending on wheter you have a split secondary and when you have 2 seperate secondaries?
#6 |
Yep, you remove diodes D2,D3,D6 and D7 then jumper between the remaining diodes to form a Bridge rectifier. I am pretty sure that I have it wired correctly. Would a leaky cap after the bridge allow some AC to get through. Maybe my V- side cap is not healthy.
#7 |
Sounds like one diode is'n working and you have only half way rectification at the low level side. That would explain the drop when loaded.
Do you have a scope, to see that the ripple at the lower voltage side is higher & half-wave? Jan Didden
/Another new issue: Linear Audio Volume 3! |
#8 |
Well the power supply was alright, I disconnected my source input and my voltage issue disappeared. Turns out my source has some DC on it's output as well one side had some small amout of AC also. I have put a 1uf cap on the signal inputs and the problem has gone away. Thanks for the suggestions they always cause me to put more effort into my problem solving.
Thanks Mark |
| Rectifier voltage difference, Why? | Original Burnedfingers | Tubes / Valves | 15 | 16th January 2006 12:46 PM |
| Pearl input voltage difference | Zappa | Pass Labs | 1 | 6th April 2003 08:15 PM |
| Page generated in 0.11158 seconds (70.19% PHP - 29.81% MySQL) with 10 queries |
