Old 14th October 2006, 02:25 PM   #1
Default Gainclone kit passive pre configuration
I am going to build a compact system by integrating a Monica2 dac, stepped attenuator and lm3875 kit into one box.
I currently have a 100K attenuator that I'd like to use. Couple of questions:
1. Will 100K with >10cm connections to the amp board be ok? The capacitance of the short run will be minimal.....
2. Will the Monica2 be happy driving 100K? I think the dacs low output should prefer a higher attenuator input impedance.
3. Do I need the 22K resistor from input signal to ground on the ampboard if the 100K attenuator is hard wired and very close? This may be a stupid question, but it seems like we have two resistors doing a similar job... Put it another way, is 22K optimal after a 100K attenuator?
Old 15th October 2006, 05:01 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Is the attenuator a log type???
Old 15th October 2006, 11:27 AM   #3
yes - 100k log attenuator
Old 16th October 2006, 02:52 PM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
The best answer is to try it. You could also buy one of those 50K (and or 20K) 9mm Alps pots from Farnell or Jaycar and try that to see if you hear any difference.
I would personally want an active stage between pot and GC.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 16th October 2006, 02:59 PM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: Gainclone kit passive pre configuration
If you are using minimized GC configuration, you need 22k shunt resistor, otherwise, with only a 100k pot you will get high DC offset at lower volume settings (shunt resistance >22k)
50k or 25k pot works better than 100k.
I obtained very good results with a pot directly at amp's input (you don't need an additional active stage here) and an active buffer at DAC's output.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 16th October 2006, 07:05 PM   #6
keps is offline keps  Philippines
Does it mean 10k pot works better than 50k or 25k pots?
Old 16th October 2006, 07:13 PM   #7
Nuuk's Avatar
No! Remember that you must match the impedance right the way through the chain! Try Googling the subject.
Old 16th October 2006, 07:15 PM   #8
roger that.
(Gainclone Preamp) ACTIVE or PASSIVE ? nickthevoice Chip Amps 27 26th July 2011 10:28 AM
Passive bi-amping with gainclone?? steveline Chip Amps 21 22nd August 2008 09:09 PM
Best Gainclone configuration for Jordan JX92S Drivers A Sanchez Chip Amps 32 18th April 2008 11:44 PM
PSU for 5 Channel Gainclone: wich configuration should i use? Bassterror Chip Amps 1 29th January 2007 12:53 AM
What is your Gainclone Configuration? king30 Chip Amps 18 3rd May 2003 10:54 PM
Page generated in 0.09984 seconds (77.14% PHP - 22.86% MySQL) with 10 queries
