Integrated gainclone, NOSDAC and DAR
Old 14th October 2006, 01:41 AM   #21
FastEddy is offline FastEddy  United States
FastEddy's Avatar
Excellent ... thanks fior the clarification. Keep up the good work.
! & 2: I as well have no problems with the EtherNet connections, wireless or otherwise. I guess I was just trying to discover your motives if other than convenience = no wires. (I have not seen any effect of the wired connection visa vis power supply noise feed through, etc.)
3: " ... I personally feel you are better off choosing your own DAC and using the SPDIF out on the SB3. I have been extremely happy using an outboard DAC; first a modded Bel Canto and now Peter's NOSDAC. ..." ... good advise.
Thanks for taking the time to answer my pecular questions.
Old 14th October 2006, 04:08 PM   #22
FastEddy's Avatar
Also I did a little web search for "NOSDAC" and "Peter's NOSDAC" and got a lot of older links, mostly in several languages other than english. Got a link to the one you are using? ... Got comments about performance, usability, DIY stuff?
Old 14th October 2006, 04:41 PM   #23
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Integrated gainclone, NOSDAC and DAR Send a message via AIM to Peter Daniel
"Peter's NOSDAC" has been recently mentioned here: http://www.6moons.com/audioreviews/a...e5/system.html
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 15th October 2006, 02:41 PM   #24
josiphal is offline josiphal  Croatia
Size of aluminium tubes in your new products, amp is in 10cm x 5cm, and dac is in 8cm x 4cm?
Old 15th October 2006, 03:10 PM   #25
Amp is 3 x 6", DAC is 2 x 3" (1"= 2.54cm)
www.audiosector.com
Old 5th November 2006, 06:21 PM   #26
Kooka is offline Kooka  Italy
Kooka's Avatar
Originally posted by neil_kaye
mounted NOSDAc
I am very interested in your realization, and I have one question: isn't the Squeezebox supplied with a good dac? Didn't you use it? Did you use another one? thanks.
Old 6th November 2006, 02:54 AM   #27
neil_kaye is offline neil_kaye  United States
neil_kaye's Avatar
Kooka,
The squeezebox does come with it's own onboard DAC. As a stock unit i found it quite flat so have always used an outboard DAC. First a Bel Canto and now Peter's NOSDAC. With an outboard DAC the I found that the sound improved tremendously. If you search the forums you will find that others have had similar experiences and opted for another DAC.
In the next week or so i plan on implementing a buffer circuit, at which point i feel that i will be in a better position to comment on the sound of the whole get up
Old 6th November 2006, 06:32 AM   #28
Kooka's Avatar
I see. I'm looking forward for your comments about the buffer...
Old 18th November 2006, 11:21 PM   #29
neil_kaye's Avatar
Default added buffer
I finally added Peter's buffer. The sound has improved remarkebly and the amp seems to have an easier time driving my speakers.
I can only describe the sound as being easier and more control over the base.
I didn't swap out the coupling caps on the DAC, and once eveything was wired up i hadn't left any room to desolder... oh well next time.
I am very happy with the way it all worked out. It is dense inside the chassis, what with 4 toroids, one smps and 6 boards.
Old 19th November 2006, 08:44 AM   #30
Kooka's Avatar
I am sure it is very difficult to take more pictures inside the case, but how did you intalled the squeezebox disply inside the case? I mean, I can't see any screw in the front panel...
Integrated gainclone, NOSDAC and DARHide this!Advertise here!
Trouble shooting LM3875 and NOSDAC neil_kaye Chip Amps 6 10th October 2006 08:17 AM
Integrated gainclone w/ NOS DAC and SB3 neil_kaye Chip Amps 5 18th August 2006 05:17 PM
Integrated Amp toman_9 Solid State 0 22nd January 2006 12:36 PM
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
The ultimate integrated frugalphile gainclone yldouright Chip Amps 62 24th July 2005 11:51 AM
