| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I've about completed my 5687 based linestage, finished my FE87e Fullrangers, so what's left? Right: A (power)amp! I've read about tubebufferd gainClones, but I don't want to something like that: My linestage will be to far away to implement series feedback, and: My linestage has a (voltage)gain of about +26dB.... That is: 1v in, 20v out... I don't want to keep the linestage's inputs verrrrry low, so I end up having 2v output (and a lot of noise... :-( ), so my question is: How can I build a gainclone thinggy that accepts some 20V input? (I thought of a simpel voltage divider, but there must be some more elegant way) Hint welcome! Cheers, Paul
Demagogue: One who preaches a doctrine he knows to be untrue to men he knows to be idiots. H.L. Mencken |
#2 |
You don't want to attenuate (reduce) the level only to amplify it again. That will do nothing but increase the noise level.
The LM3886 can handle input voltages in that range (20V). You just need to adjust the gain to a low value (like 1 or 2). Gain, which is the factor by which the amplifier multiplies the input voltage, is set with external resistors. There's one potential problem - like many op-amps, the 3886 has stability problems at low gain levels. In other words, it tries to stop being an amplifier and become an oscillator (tone generator). At best, this makes the amp useless. At worst, the chip can burn up, though the 3886's substantial protection circuitry would probably preven that. This thread had a good discussion of how to make a low-gain gainclone: Gainclone...No gain, YES pain. Good luck. Reid |
#3 |
Hi bibster,
use OPA549 - there are some people who prefer it to LM38xx chips. It is known that it works better in low gain configurations (G=1 or 2) - it has wider bandwith when configured that way. No stability problems at all, other specs also very good. Take a look at: http://focus.ti.com/docs/prod/folders/print/opa549.html http://www-s.ti.com/sc/ds/opa549.pdf |
| What should be the optimim level of Input Signal to a LM3886 based amplifier | kuldeepsingh | Chip Amps | 9 | 14th May 2008 10:17 PM |
| UcD400 and high level sub input | chrisb03 | Class D | 51 | 21st May 2007 12:20 PM |
| JBL Sub high level input only | Dr Moreaux | Subwoofers | 5 | 22nd April 2007 03:04 AM |
| Sub-woofer high level input | StalfoS | Solid State | 2 | 15th February 2007 11:00 PM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| Page generated in 0.07681 seconds (72.70% PHP - 27.30% MySQL) with 10 queries |
