Old 9th October 2006, 07:46 PM   #1
Razbi is offline Razbi  Finland
Default LM3886 Stereo Amplifier problem
Hi!
I'm finishing my project of stereo amplifier with snubberized power supply based on Brian's Kit (http://www.chipamp.com). Yesterday I powered the amp and measured DC offset between the output terminals. It started with 110mV and then went down towards zero. Is this normal?
Second problem is the power LED. It doesn't go on. I tested the circuit with another led (certainly working one) with same results. Then I tested the resistor and diode on circuit, they're fine, but I'm not sure about the capacitor. How can I test that? I didn't get any voltages or currents measured from resistor's ends when amp was powered.
I also tried the amp with test speaker, but didn't get sound out of it.
I attached a couple of pictures, if they're helping any.
I would be very pleased if you can help me out of this problem.
Old 9th October 2006, 08:14 PM   #2
can you keep the safety earth attached to the chassis and disconnect the audio ground from the chassis?
Keep the audio ground floating above the chassis and add a disconnecting network from audio ground to safety earth. Do not remove the nut securing the safety earth, instead add the disconnecting network above the first nut and then use a second nut to secure.
The disconnetcing network can consist of a ceramic cap // power bridge diode// power resistor// power thermistor, or any combination of these.
regards Andrew T.
Old 9th October 2006, 08:15 PM   #3
your input cables from RCA to PCB are run separately. Try twisting them tightly together.
regards Andrew T.
Old 9th October 2006, 11:59 PM   #4
john65b is offline john65b  United States
john65b's Avatar
Your power supply board is fully populated with all eight rectifier Diodes, so it is set up for a transformer with Dual secondaries (4 wires). If you have a center tapped transformer (3 wires) you need to modify the power supply board and get rid of 1/2 the diodes and put in a few jumpers.
If you are running a centertapped transformer, see Brian's LM3875 Instructions on how to jumper the right diodes. The LM3886 instructions do not identify how to wire a centertap transformer.
Old 10th October 2006, 06:36 AM   #5
Transformer has dual secondaries. But thanks still.
Old 10th October 2006, 10:03 AM   #6
Stuey is offline Stuey  Australia
Try reversing the LED - I think the instructions have the LED wired incorrectly.
Stuey
Old 10th October 2006, 11:24 AM   #7
can you measure the voltage across the LED and across the feed resistor?
The LED should have about 1.5V to 2V across it.
regards Andrew T.
Old 10th October 2006, 12:37 PM   #8
I was pretty sure I'd wired my LED up as instructed in the kit and the LED didn't work, hence my post. I reversed mine and it worked...
Cheers
Stuey
Old 10th October 2006, 01:01 PM   #9
Nordic is offline Nordic  South Africa
Nordic's Avatar
Heck, you have space left for 2 more channels....
Nice strong build there
LM3886 stereo - PCB design Razor_x Chip Amps 2 3rd July 2009 12:18 PM
LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules Jackson Audio Vendor's Bazaar 2 8th April 2007 12:17 AM
lm3886 stereo setup rs1026 Chip Amps 1 30th September 2004 06:25 AM
LM3886 amplifier problem mbates14 Chip Amps 9 11th August 2004 08:42 PM
Page generated in 0.11255 seconds (80.53% PHP - 19.47% MySQL) with 10 queries
