Old 8th October 2006, 03:07 AM   #1
Default Need yea or nea on input switch
Any problem with using this switch
for an input selector?
Thanks,
David
Poor stereo mix? Switch to mono! Perfect.
Old 8th October 2006, 04:32 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
I have used worse...
Old 8th October 2006, 04:39 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Default Re: Need yea or nea on input switch
Thanks,
David
It's a shorting.Why not go for non-shorting???
Old 8th October 2006, 04:58 AM   #4
Nordic's Avatar
I think thechnicaly speaking, make before brake is in fact the right option...
Old 8th October 2006, 07:11 AM   #5
Nordic's Avatar
wait, I'm wrong... too early in the morning it seems.. make before break is for attenuators...
Old 8th October 2006, 07:58 AM   #6
lineup is offline lineup  Sweden
lineup's Avatar
this is true for most audio switching or steeped switches for volume
make before break
Because if is a resistor that keeps down impedance on the other side of switch
this resistor can be important.
The lack of a bias resistor at input terminal, for example
can make amplifier go really crazy,
if so only for a short moment.
Can make blips sounds.
lineup
Old 8th October 2006, 08:41 AM   #7
v-bro is offline v-bro  Netherlands
v-bro's Avatar
Ladder type attenuators need break before make (otherwise the resistors can be paralelled for a moment resulting in higher volume (blips) between steps.
Series type attenuators need make before break type switches, otherwise the resistance parallel to the input of the poweramp will be broken off between steps.
Input switches need break before make on the positive wire in order to keep the blips out. The bias resitor should be placed on the output of the switch (input of amp), which is allready the case in most amps...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 8th October 2006, 02:02 PM   #8
Good Morning all. I guess by the sum of the responces, the switch will at least suffice. Any suggestions welcome.
Old 8th October 2006, 02:09 PM   #9
Ooops! Now I'm confused. Do I need "make before break" or "break before make"???
The amp is a Peter Daniel LM4780 parallel stereo.
Thanks.
Old 8th October 2006, 09:14 PM   #10
v-bro's Avatar
Break before make, otherwise there's a moment where sources (for example cd-player and tuner) are parallelled inbetween switching.
The only crucial thing is that ground stays connected between source and amp....
Input Switch? markw51 Tubes / Valves 0 23rd December 2006 01:08 PM
Can I switch between two input receivers? riotubes Digital Source 20 23rd August 2005 07:11 PM
input switch for BOSOZ Gabrielshorn Pass Labs 1 19th September 2003 06:57 AM
A good input switch for BOSOZ Gabrielshorn Pass Labs 2 5th September 2003 03:25 AM
Relays as input switch? Nisbeth Solid State 26 28th October 2002 07:12 PM
Page generated in 0.14232 seconds (62.24% PHP - 37.76% MySQL) with 10 queries
