| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I need an information to designing my GC's buffer.. The quesiton is; Whats the output level of a(ny) PC type soundcard? Does it around 1000mV or lover? Because i must determine my new GC's input buffers gain. Its actually=2 and i need 970mV for my GC. So i need 485mV effective input voltage. Do you think 2 is enough gain for me? Thanks a lot in advance.. |
#2 |
Line level signals (unless we're in the crazy world of car audio) are 1 V peak. So you have an absolute maximum of 2V peak to peak swing. Many soundcards are a fair bit below a 1 V line level at maximum output though. You could always download a tone generator program and measure the output to be sure.
the word "buffer" and "gain" should not describe the same thing. A buffer has a gain of 1, and works as a current source. Once you include gain in the equation, your leaning closer towards an active preamp. If you're just using an op-amp for this "buffer", then adjusting the gain is as simple as replacnig a resistor. If you don't have enough, or it's too much, 5 minutes later it's changed .
#3 |
Ok i see. I use an op-amp (TL072) for input level adjusting. Then i call it "buffer". Yes it has a gain (x2) so i made a preamp.. I do not need a current source and as you said i dont need a buffer! Under that situation do i need a preamp like this?
And another question; 2Vpp makes 1.4Veff. As i can understand for LM1876 input with x20 gain i need 0.976Veff. So i need a preamp for full output? Am i wright? The "buffer" is like that; Thanks a lot. |
#4 |
This can be a buffer with a gain of 2X
SivanandBalan |
| Convert Line Level to Electric Guitar Level | miallen | Solid State | 4 | 16th May 2010 01:22 PM |
| speaker level input vs line level question | crippledchicken | Subwoofers | 4 | 17th July 2007 03:36 AM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| how to bring down line level signal to preamplifier level | deji | Solid State | 15 | 15th April 2004 04:13 PM |
| Line Level, Balanced Voltage Level... | dkemppai | Solid State | 3 | 10th December 2002 11:04 PM |
| Page generated in 0.08499 seconds (71.84% PHP - 28.16% MySQL) with 11 queries |
