What happens if the battery supply is off balance ?
Old 6th October 2006, 06:48 AM   #1
Will is offline Will  Malaysia
Default What happens if the battery supply is off balance ?
I have plans to power up my 3875's with 4xSLA 12v in balanced mode, i.e. +/- 24 supply. What would happen if lets say, one side of the battery (in the long run) sags, making the voltage off balance by 1 volt or more ? Will it burn my speakers ?
regards,
Will
Old 6th October 2006, 07:05 AM   #2
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
There is dc feedback as well as ac feedback from the output, so the dc offset at the output will allways be controlled and it won't be a problem. The amp will still work with (say) +20V and -24v, but obviously it will clip asymetrically.
Old 6th October 2006, 08:04 AM   #3
Thanks, that's comforting to know. I also plan to have a battery indicator for both sides of the supply, and most likey will not run off by more than 2v with manual observation.
cheers..
Old 6th October 2006, 04:39 PM   #4
SpittinLLama is offline SpittinLLama  United States
It will be fine. I ran a LM3886 with a +6V and -10V to run it down to 16V supply (the cut offs are asymmetrical) and there is no increase in DC offset. You wil be fine.
-SL
What happens if the battery supply is off balance ?Hide this!Advertise here!
C- Battery Supply dsavitsk Tubes / Valves 4 14th May 2008 09:08 PM
Battery supply. harwoodspark Analog Line Level 10 23rd December 2007 05:28 PM
converting a DAC to DC battery supply Puggie Digital Source 1 22nd April 2006 05:07 PM
Battery powered Balance Line Stage icceman Pass Labs 10 26th December 2003 01:35 AM
Battery Supply Help. RichardJones Solid State 4 11th June 2003 02:23 PM
Copyright ©1999-2017 diyAudio
