Options for a less expensive attenuator option? Options for a less expensive attenuator option? - diyAudio
Old 5th October 2006, 11:48 PM   #1
Spasticteapot is offline Spasticteapot  United States
Send a message via AIM to Spasticteapot
Default Options for a less expensive attenuator option?
Attenuators are expensive. For the price of two gainclones, I can buy a single DACT series attenuator. Kits are'nt cheap either; they start at 50$ on eBay.
So, what's a cheapskate to do?
First, there's the series attenuator option. Common (and inexpensive) break-before-make switches can be used, and they don't need many resistors. However, some have reported a certian amount of "fuzz" from sending the signal through so many resistors.
Price: About 5$ for a 2-deck 12-position Russian surplus rotary switch on eBay, and about 6$ for 24 Dale 1/4w 1% resistors from Mouser.
Secondly, there's the ladder option. Although a massive pain in the kiester to make, a ladder attenuator has the benifit of (in theory) sounding much better than a series attenuator. The pricetag, however, is a bit on the nasty side.
4-pole 22 position rotary switch: 25$
http://www.triodeelectronics.com/4pol24posals.html
88 Dale metal film resistors: about 15$
Total cost: 40$.
Finally, there's the digital attenuator option. If you can figure out how to make it work, it's possible to build one of these reasonably cheaply. However, they're still not that cheap.
Old 6th October 2006, 08:49 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
http://glass-ware.stores.yahoo.net/aikampstepat.html
The Aikido attenuator PCB kit $29
"The kit includes 32 resistors. Resistors vary in quality and in price; some go for as much as $12 each. Fortunately, this clever attenuator uses fewer resistors (only 32) than would be expected from a conventional 32-position stepped attenuator, as two series attenuators would need a total of 72 resistors; and two ladder attenuators would require 140 resistors. (Resistors, like capacitors, are the objects of hot debates, where one audiophile’s “rich tonality” is an other's blurry and bloated mess, and one audiophile’s “clarity” is an other's cold and harsh stridency; so, generic 1% MF resistors are included, but any of the exotic resistors could be used instead. But really, any type of resistor in this attenuator will make a better sounding volume control than even the best potentiometer.)
Old 7th October 2006, 05:59 AM   #3
Tempting, but 60$ for a pair is a bit much. A two-deck 21 position silver-plated-coper rotary switch is about 10$ on eBay nowadays. And metal film resistors are 10 cents each in some cases.
Besides, my "40$ solution" is a true ladder attenuator, and costs less. Plus, it's only one knob.
Options for a less expensive attenuator option?Hide this!Advertise here!
Is it good option? Prabot Everything Else 2 4th June 2008 10:46 AM
Electrocution not an option ... Bluto Analogue Source 13 28th March 2008 04:18 PM
I need 12v DC- whats the best option? Rob11966 Tubes / Valves 4 7th July 2007 10:16 PM
ART DI/O DAC Audition with option to Buy mrdon Swap Meet 0 3rd December 2005 07:30 PM
Copyright ©1999-2017 diyAudio
