A little more twisted than usual....
Old 4th September 2008, 03:41 AM   #161
Russ White is offline Russ White  United States
Russ White's Avatar
Originally posted by sts9fan
uhg don't really feel like ripping this thing appaart. Can you expain how/why this could happen?
Well I can't say for sure without taking apart your speakers.
But my guess is that the Zobel will help tame the problem if its because of an extremely inductive load.
I would have no way to know if it will actually help except to try it for for myself.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 5th September 2008, 01:52 AM   #162
sts9fan is offline sts9fan  United States
Hi Russ,
Can you post the schematic for the TXO-2. I see you have removed it from the site and i did not save it.
thanks
Kris
Old 10th September 2008, 05:39 PM   #163
chatziva is offline chatziva  Greece
chatziva's Avatar
Originally posted by Russ White
Or you can even leave the rectifier in place as you will only lose something like .4 - .5V With the rectifier in place it does not even matter what polarity you connect the DC as long as GND is correct.
Cheers!
Russ
Alrite that IS clever!! Thanks Russ
Old 15th June 2013, 03:49 PM   #164
Sproggit is offline Sproggit
Originally Posted by Russ White View Post
Hey Folks,
I have a few projects that have a lot in common, and they are beginning to run together in terms of concerns. In fact the ideas are modular, and build on each other.
Examples:
Twisted Sibling - A balanced line driver/preamp and SE/BAL converter.
Twisted X Overture(TXO) - A balanced symmetrically bridged power amp.
Twisted X Symphony(TXS) - Same as TXO but with two OPA549 working at much lower gain (the gain is handled more by the THS41xx in this case).
Anyway, I have made a whole lot of progress on this stuff, but it does not belong in any single thread, until now. I have decided to launch his thread to discuss the modular approach to all three projects. More projects are planned and in the works based on the modules contained here.
Using the modules I have designed one could create a power amp project of anywhere from 50W to 300W or more....
Anyway here is an article to get people started. I am very interested in feedback from the community here, and ideas. This document is pretty high level. I don't want to lose people in details just yet. But this is the place to talk about it, and expand on things. Any important info will be added as a new revision of the document.
I will probably write more detailed articles later should people be interested.
A Very Twisted Missive
Cheers!
Russ
OK, I need 13 x TXS.
Who do I have to convince to let me buy boards / layout files?
BR
Jan
A little more twisted than usual....Hide this!Advertise here!
need an opinion..... as is usual Madmike2 Multi-Way 12 17th March 2008 12:15 PM
Not your usual hum problem. Please help. madisonears Chip Amps 10 27th February 2008 11:44 PM
A Dummy Load different from the usual fotios Solid State 5 1st March 2007 08:38 AM
Not the usual box..... (PIC) MCH Multi-Way 9 10th February 2006 11:13 PM
