diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   the best transformer rail voltages for gainclone? (http://www.diyaudio.com/forums/chip-amps/87436-transformer-rail-voltages-gainclone.html)
araven 30th September 2006 03:03 PM
I'm currently building a gainclone using a LM4780, and was wondering what the best transformer spec would be?
I like the look of the THD+N graphs (and other graphs) when using 35v and 8ohm speakers. The problem is, i want the amp to be flexible and i can't gaurantee that I won't use speakers with a lower impedance at some point.
Also, what's a good power rating to use? At a guess i would assume a minimum of about 200VA.
Thanks,
Andy
araven 30th September 2006 03:08 PM
Forgot to mention, I currently already have 2 suitable toroids in my spares box to choose from.
1. 22v 225VA (which should deliver about 31v after rectification under load)
2. 25v 300VA ( 34.5v after rectification under load)
Thanks,
Andy
jaycee 30th September 2006 10:31 PM
Either would do, really. I'd go with the 25V 300VA unit, just make sure you dont crank it when used with 4 ohms :)
Resources saved on this page: MySQL 18.75%
