Transformer question for Chipamp...
Old 9th October 2006, 07:11 PM   #61
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
I think that would give you +-56V rails, not 28V.
Old 9th October 2006, 08:36 PM   #62
john65b is offline john65b  United States
john65b's Avatar
If you have a 20V - 20V toroid on the AC side of a rectifier, you get the same as a 40V - 0V on the AC side of a rectifier, which is +/- 28VDC.
I tried it...
Old 9th October 2006, 08:50 PM   #63
R.I.P.
NO!
If you use 20-0-20 then you get +-28Vdc because the 0V gives a reference.
The 40-0 gives 56Vdc and there is no 0V reference to split the 56Vdc in half.
You have been advised (by others) to avoid using a virtual earth for the power amp.
I now concur with this advice.
The reason I arrive here is that you would require a high current power amp to generate the virtual earth and having generated it artificially there is no guarntee that it will sound nice or even work stabily. A lot of development time and cost to avoid rewinding or buying a transformer.
regards Andrew T.
Old 9th October 2006, 09:51 PM   #64
john65b's Avatar
Very well. I will leave it alone.
Old 10th October 2006, 01:45 PM   #65
john65b's Avatar
Yes, after reading AndrewT's response again, I see my mistake. The 40V-0V secondary has no center reference to get the values I am seeking.
To total voltage across the AC pins of a rectifier may be the same from 20V 20V (centertapped case) versus a 40V 0V (standalone secondary case), but output voltages are referenced from different points...
Thanks again.
Transformer question for Chipamp...Hide this!Advertise here!
Chipamp.com PSU with CT transformer cabbagerat Chip Amps 8 1st February 2008 01:40 PM
Will this transformer work with the ChipAmp kit? Spasticteapot Chip Amps 8 18th January 2006 10:58 AM
UK (?EU) Transformer for Chipamp Group Buy jimbo1968 Group Buys 2 12th June 2005 01:00 PM
