Old 29th September 2006, 01:23 PM   #1
Default LM1875 design advise....
I've built an LM3875 gainclone and now want to try a high quality 1875 based one.
Any suggestions for circuits etc?
Thanks.
Old 29th September 2006, 01:42 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: LM1875 design advise....
Thanks.
... data sheet..?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 29th September 2006, 03:24 PM   #3
Thanks, Jan. I was thinking of other designs that circuit topologies that have proved to offer good sound quality.
Also, recommendations for the 2.2uf input cap, please?
Thanks.
Old 30th September 2006, 01:35 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
No cap.
Old 26th October 2006, 03:04 PM   #5
Default Transformers
Another (dumb?) question for you:
Would one 50Watt 2x18v per channel transfromer be sufficient for a low power 1875 amp?
Thanks again,
Lee
Old 26th October 2006, 03:06 PM   #6
Leolabs's Avatar
Default Re: Transformers
Thanks again,
Lee
Why not??BTW,is 50VA not watts.
Old 27th October 2006, 10:17 AM   #7
what is the difference between VA and W??
Old 27th October 2006, 11:24 AM   #8
paulb is offline paulb  Canada
Thanks.
http://www.diyaudio.com/forums/showt...24#post1012124
Generally (not precisely) speaking, W is used in this forum for amp output power, while VA is for transformer output rating. VA is used because the W you get from a power supply depends on several other factors besides VA.
lm1875 psu design BionicSniper Chip Amps 28 15th March 2009 07:27 PM
Help! Speaker design advise needed beeroclock Full Range 0 30th March 2007 11:58 AM
LM1875 - pcb design zatramusic Chip Amps 2 15th February 2006 06:13 AM
Page generated in 0.08319 seconds (76.93% PHP - 23.07% MySQL) with 10 queries
