Wiring Toroid 14V non center tapped for PSU
Old 22nd September 2006, 10:15 PM   #1
civilmonkey is offline civilmonkey  Canada
Default Wiring Toroid 14V non center tapped for PSU
I Apolgize if this has been covered, I've searched a on few forums with no luck.
I pulled a toroid transformer from a halogen light fixture. It's 105VA, 120 VAC in, 1 x 14 VAC out, not centre tapped.
I tired using two bridges, so I have two +/- 12VDC supplies. I tied the bridges together (one - to one +, connected to mains ground) to get a zero volt rail, but that didn't work and results in melted wires (no blown fuse though)!
If I use one bridge, and take two +/- 12 VDC supplies from it, can I use the mains ground as a zero volt wire?
My plan is to build a gainclone using LM1875 chips. I don't need a lot of volume.
Thanks in advance.
Old 22nd September 2006, 10:59 PM   #2
cpemma is offline cpemma  United Kingdom
The only way I know to do this is covered by Rod Elliot here for a preamp supply using a voltage doubler and regulators, but I don't think it's suitable for the current draw of even a modest power amp.
You really need a second similar transformer, or a pucka CT or dual secondary one.
Old 22nd September 2006, 11:56 PM   #3
paulb is offline paulb  Canada
Use a single-ended power supply version of the LM1875 circuit. See page 2 on the datasheet:
http://cache.national.com/ds/LM/LM1875.pdf
Never mind the wags who will tell you that an output capacitor is evil. So you can just use a single bridge rectifier to get about 20VDC. Works fine.
Old 23rd September 2006, 11:13 AM   #4
Certainly OK with less high-end speakers that wouldn't know what to do with low bass if they got some. Was a time most small amps were single-rail...
Just out of curiosity, is there any problem using LM1875 in bridged mode on single-rail (with no output caps)? Never seen a circuit anywhere.
Old 23rd September 2006, 01:53 PM   #5
Even with a +/- supply, there are power supply caps effectively in the circuit with the speaker anyway. So you always have a capacitor somewhere. Bass response simply depends on the value of the capacitor.
LM1875 in bridge mode works fine, I actually have one sitting behind me at the moment. It uses op amps to drive it and split the phase. It's only useful if the speakers are 8 ohms or higher, as in bridge mode each amp sees half the impedance and the LM1875 is only spec'd for down to 4 ohms.
Old 23rd September 2006, 02:01 PM   #6
See attachment. I can run this amp from a single supply by just providing a reference ground at half the supply voltage (it doesn't need to provide much current).
This circuit was based on an article in, I think, Popular Electronics quite a few years ago. U2A is a servo feedback that keeps the output DC offset voltage at 0.
Old 23rd September 2006, 07:59 PM   #7
Thanks for the ideas. That single supply schematic seems like it's worth a try.
Cheers
Old 23rd September 2006, 08:12 PM   #8
Yes, I built a single-supply version (right from the datasheet schematic) for a desktop speaker in a telephone case. Here's what my board looked like. I used verboard, with the strips of copper on one side. I used individual diodes (on the right) instead of a bridge rectifier. Ran from 16VAC.
Wiring Toroid 14V non center tapped for PSUHide this!Advertise here!
Wiring Filaments with Center Tapped Secondaries JBasham Tubes / Valves 22 20th March 2009 08:24 PM
Transformer wiring question, series, parallel and center tapped swin1 Power Supplies 12 7th November 2008 07:58 PM
Center tapped transformer help Buzzy Parts 2 8th August 2008 09:35 AM
WTB 2:1 center tapped trafo in the UK MikeHunt79 Swap Meet 0 15th January 2008 01:46 AM
Two Transfomers => Center Tapped? Myren Analogue Source 6 12th April 2004 02:22 AM
