| Chip Amps Amplifiers based on integrated circuits |
#61 | |
Since it is floating "chassis" is irrelevant. I would be tempted to keep it between the pair of amp modules but close to the PSU. However, I believe a much more important issue is keeping the LOOP AREA of the PSU cables VERY SMALL. Those are the cables forming the centre tap, the two AC cables to the rectifier, the two +v & -ve cables to the PCB. But some PCBs have well separated PSU & Power ground input connections. The designer is either very clever or has not recognised the relevance of small loop area and the impulsive magnetic fileds coming from single cables.
regards Andrew T. |
#62 |
Obviously twisting grounds together (PG- and PG+) helps? Does twisting any other specific set of wires help?
Luckily I got some cool twist pliers from my motorcyle trackday tool box
#63 |
when two cables carry the same current but in opposite directions then close coupling them will attenuate the magnetic field. Twisting achieves an extra measure of attenuation. So, any pair that carry equal and opposite currents can be twisted. Transformer psuedo centre tap. Transformer AC to rectifier. Rectifier to smoothing caps. Loudspeaker to PCB, but don't connect the return. It goes to audio ground. smoothing caps +ve & -ve AND 0v to PCB. note: that last one NEEDS the 0v wire to make a threesome. The currents in the threesome cancel but not in any pair from the three. A warning on the Loudspeaker suggestion. The single return passing near the PCB on it's way to the audio ground may be worse than the line led to speaker terminal and then return from terminal led straight to audio ground.
regards Andrew T. |
| earthing advice on a US amp | woodturner-fran | Tubes / Valves | 7 | 16th January 2009 12:25 AM |
| New Cabinet Opinions & Advice Sought | Thomo | Full Range | 8 | 30th December 2008 11:03 PM |
| Fostex E16 advice sought | john blackburn | Analogue Source | 0 | 18th September 2007 08:58 PM |
| Woofer advice sought | cs | Multi-Way | 7 | 29th January 2007 09:08 PM |
| HiFi Advice sought | Gina | Everything Else | 80 | 11th December 2002 02:19 PM |
| Page generated in 0.08145 seconds (63.12% PHP - 36.88% MySQL) with 10 queries |
