One of my OPA541AP short without knowing why
One of my OPA541AP short without knowing what is the reason.
I am using 100mf Blackgate N with 1000mf Balckgate Standard and haveing very wonderful result however, I want to try only 100mf Blackgate N which is said to have best mid and high frequency.
So I remove the 1000mf standard, without touching any others parts at all.
But when I turn on my amp there is a lound noise from one of my speaker and noise from the other side.
So I check both chanel, nothing wrong. I did try again, same thing happen.
Then I connect the 1000mf standard back but one of my chip is short resulted in 29V DC offset at the speaker terminal. :bawling: .
The worst thing is I still do not know why??? :whazzat:
My friend, you may still lucky enough.
Check your grounding, power and signal ground may loosen or separate when you remove the BG 😀
I've a similar symptom when I forgot to connect power gnd. to signal gnd. 😉
