diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   To decouple or not to decouple. (http://www.diyaudio.com/forums/chip-amps/86389-decouple-decouple.html)
Colescuttle 12th September 2006 08:46 PM
I'm putting together one of Peter's LM3875 kits in a monobloc format. I have 4 Jensen 4 pole electrolytics left over from another project. Would I gain anything sonically by inserting one each in the + and - rails between bridges and amps? I'm using a 300VA/22v Plitron transformer.
Thanks!
Nuuk 13th September 2006 07:28 AM
There's one way to find out! :att'n: ;)
angchuck 13th September 2006 08:09 PM
2 Attachment(s)
The jensens are so good that you should make a separate velo board and hook them up as shown. If you have 2 caps, then just use one half of the configuration. Then you can compare power supply configurations and have more fun.
Colescuttle 13th September 2006 08:38 PM
Thanks, Angchuck.
Your diagram didn't come through. Could you attach it to an email to george_cole*bellsouth.net.
Thanks for the help.
AndrewT 15th September 2006 08:13 AM
re the 4pole electrolytics.
Can you explain the difference between IN & OUT?
Alternatively, what is connected internally?
angchuck 15th September 2006 09:30 AM
Hey Andrew,
This diagram was posted by Chris (ClassD4sure). Maybe the experts in the forum can chime in on how the jensens work.
i don't know how these 4 poles Jensens or BHC's are constructed. But they are polarised with 2 +- terminals, and they are not 2 radial caps rolled into one. Either - terminal works with either, or both + terminals.
Maybe the jensen white papers can help, it didn't really help me answer your question. I have no engineering background.
http://www.jensencapacitors.com/audi...ers/4pole.html
I am pretty much a newbie, but i am always curious. I tried // 2 normal caps in series but that didn't work like i imagined. :cannotbe:
Anyway, i was telling George that this was the best configuration i have built for my ucd180 and nigc. The regulated PS was a close second and third would be the capacitance multiplier. But that one runs the amps so hot, i think it might have caused my ucd's some inherent problems. Thus, unregulated snubberised PS would be my unqualified third placed. And 8X Pana FC's straight up were my least preferred, but they are still pretty good.
In the back of my mind, the reputation of Blackgate FK looms.
Chuck
AndrewT 15th September 2006 10:35 AM
either // (parallel) or series for the pair, not both.
Resources saved on this page: MySQL 18.75%
