Old 12th September 2006, 08:40 PM   #1
Default Please Help!!! me decide on a chipamp
I was excited to start on a chip amp but with so many variations out now I don't know where to start. There are some specific things that I am looking for though.
I'm looking for a gainclone that has
- atleast 25-50w per channel
- the least THD% and most headroom as possible (S/N%)
- two sets of balanced trs inputs instead of RCA that is selectable
- outputs to have speaker outs as well as trs that is selectable
I will be using it for my studio amplifier to power my monitors. I'm guessing I will need to add a stage for the balanced to unbalanced on the input and then another unbalanced to balanced stage on the output. Also I don't know what kind of summing circut to use for the selector switch on the input and output to ensure no added noise. And I would like a line output for a headphone amplifier. Please...... any help is appreciated. Thanks.
Old 12th September 2006, 09:12 PM   #2
N-Channel's Avatar
Send a message via AIM to N-Channel
Default Lm4765
Hi ______,
Have a look at National's LM4765 from their Overture series of ChipAmps. It has really good S/N and THD Figures (108dB @ 25W, and 0.009% THD at 1kHz). Slew Rate's not too bad: 12-18V/mS. The '4765 is actually a dual channel chipamp that will easily bridge (for balanced input-output operation) or parallel (for increased drive capability).
Here is the link: http://cache.national.com/ds/LM/LM4765.pdf
Give it a look.
Steve
Old 13th September 2006, 03:16 AM   #3
ifrythings's Avatar
The TDA7293(4) series have good specs.... 100W@8ohm
THD is 0.005% and 10V/uS SR, its able to do 4 ohm no problem and it has a differential input stage so you can use RCA or balanced pair it also has a slave function so you can run several in parallel with no problem and acording to the datasheet it also has a clipping detector built in ( I could be mistaken though)
Just my few points
David
Old 13th September 2006, 04:23 PM   #4
Keep in mind ST often stretche their specs some. The parallel slave ability is really cool though.
-SL
Old 14th September 2006, 02:59 PM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Hi Morning Star!Why not go for the simplest and popular LM3875???
Can't quite decide on a woofer... retroman Multi-Way 14 5th June 2009 02:32 AM
OB or TL - Help me decide jim rose Full Range 13 22nd March 2007 09:10 AM
how to decide these resistance value.?? titanchen68 Solid State 5 29th June 2006 12:50 PM
Help me decide on an OP-amp Cradle22 Parts 16 25th April 2005 04:31 PM
Page generated in 0.09166 seconds (80.09% PHP - 19.91% MySQL) with 10 queries
