| Chip Amps Amplifiers based on integrated circuits |
I'm in the process of building myself an active 2-way crossover (Nuuk's discrete buffer for the input, TI TLE2072s as active devices and OPA627 on the outputs).
QUESTION: Does each opamp need a 0.1uF cap 1) between each of the supply rails and GND 2) between the two supply rails (V+ to V-) 3) both of the above ? |
#2 |
... but one for each rail driving both op-amps would probably do the trick.
I would build it first, check it out, before adding any more caps than necessary other than prudent practice. (You might look / see TI's app. notes = http://focus.ti.com/docs/prod/folder...plicationnotes & http://focus.ti.com/docs/prod/folder...plicationnotes ) |
| decoupling caps for dip8 opamp - are they just there for a regulated supply? | Archwn | Chip Amps | 7 | 20th December 2006 04:52 PM |
| Opamp decoupling schemes [& Better grounding] | kaushama | Chip Amps | 5 | 8th December 2005 09:57 AM |
| opamp decoupling, and biasing | audiokid25 | Parts | 1 | 25th April 2005 08:40 PM |
| Opamp Decoupling | mrfeedback | Solid State | 17 | 3rd April 2003 01:02 PM |
| Page generated in 0.06366 seconds (73.87% PHP - 26.13% MySQL) with 10 queries |
