Old 12th September 2006, 11:48 AM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Question PT2350 chip question
Hi all,
I plan to use Princeton Semiconductor's PT2350 IC for my 2.1 project. Thats the link;
http://www.ortodoxism.ro/datasheets/...on/mXuwtxz.pdf
That chip includes;
one 12dB/slope LPF for subwoofer,
12dB/slope HPF for each stereo channel,
10dB two channel (bass/treble) tone control circuit.
THD values look good but the SNR is 87dB and that worrisome me. Has anybody tried that chip, and what do you think about the SNR?
I want to use it because its very practical solution...
Old 17th September 2006, 02:17 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Well,PTC does produce some cheap and cheerful chips for multimedia applications.You will able to find them on some low/mid end equipment,esp ones made in China Mainland.I haven't try the PT2350,but unless you pair it with some high end stuff,you still able to get good results.
Old 17th September 2006, 08:27 AM   #3
Dxvideo's Avatar
I purchased three of that chip already. And yes theyre very cheap chips (1$ each). I will use one if them for;
2 x LM4780 kits from chipamp.com (one kit stereo other in parallel)
500VA 2x25v toroidal transformer
a big (30cm) subwoofer (JBL) in a 30lt. box
2 x 8ohm 60w satellite (i dont know the brand)
Do you think that chip is suit for this system? Or should i make a better sub filter?
Old 18th September 2006, 02:30 AM   #4
Leolabs's Avatar
If the filter circuit is not the same PCB with the LM4780,you can try it out.
Old 18th September 2006, 08:15 AM   #5
Dxvideo's Avatar
Sorry i cannot understand.
"you can try it out"
You mean "try conventional 12dB LPF filter for sub" or "try PT2350"
And of course non of them will be on same PCB with amplifier!
Thanks you very much and best regards,
Old 19th September 2006, 01:40 AM   #6
Leolabs's Avatar
Try the PT2350.I mean.
Old 20th September 2006, 07:45 AM   #7
Dxvideo's Avatar
Thanks a lot.
Old 21st September 2006, 02:30 AM   #8
Leolabs's Avatar
Post your opinion after try out.
Old 21st September 2006, 08:18 AM   #9
Dxvideo's Avatar
I will..
Old 31st December 2009, 03:10 AM   #10
Default where you ordered the pt2350 ic
where did you order your ic?......
Question on DA chip Assyst1606 Digital Source 2 20th January 2009 11:54 PM
IRFZ44N Chip Question? Itsme Car Audio 12 29th October 2007 07:58 PM
Chip Amp PSU Question Lyerigolfin Chip Amps 8 16th June 2005 09:10 PM
Non Isolated Chip Question Adam M. Chip Amps 4 16th February 2004 12:37 AM
Question about chip packages soundNERD Chip Amps 1 2nd January 2004 12:58 PM
Page generated in 0.12007 seconds (67.33% PHP - 32.67% MySQL) with 10 queries
