Old 10th September 2006, 03:41 AM   #1
enzedone's Avatar
Default Completed LM3875
This is from an old Yamaha CD player from a mate which I stripped. Put a new front panel on with some perspex. Then painted and inserted a 20mm LED, Why i call it BT1(bad taste) as everyone was using mini super bright blue LED's i wanted something different.
Tranny is 300VA 25-0-25, with two bridged rectifiers 35amp 400v.
Two rails of filter caps: 10,000uf ea.
4.7uf 50v Elna at the front of each rail
100nf 275v at the end of each rail.
Sanded some plumbing nuts down with some wet & dry then drilled and counter sunk them for the screws and used them for the feet.
10mv & 5mv DC offset, so pretty happy.
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX.
Old 10th September 2006, 03:42 AM   #2
enzedone's Avatar
Default More Pics
Here is a pic of the power supply
EDIT: The caps are 22nf 1000v poly's
Old 10th September 2006, 03:46 AM   #3
enzedone's Avatar
Default Filter caps
These were put into a 25mm block od perspex. They go all the way down. There is a white perspex plate at the bottom. the rails were made up from enamelled copper wire which i had to scratch away at the corretc distances(Boring )
EDIT: The bleeder resistors are 20w 6K8
Old 10th September 2006, 03:48 AM   #4
enzedone's Avatar
Default Amp
These were the easiest of course I made sure of my earthing. placed a .5ohm resisitor and a 220nf cap in the earth path.
Mybe it's over-kill, but it is quiet.
Old 10th September 2006, 03:52 AM   #5
enzedone's Avatar
Default feet
A pic of the feet
Old 10th September 2006, 07:57 AM   #6
owen is offline owen  United Kingdom
Looks great, nice attention to detail
Owen
Old 10th September 2006, 08:26 AM   #7
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Agreed, that's good work with attention to detail and plenty of thought put into it too.
But how does it sound?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 10th September 2006, 08:50 AM   #8
enzedone's Avatar
Default Sound
Nuuk..........sounds great. this is the third LM3875. I had just finished a dual mono LM4780, but was not happy with the sound. It had heaps of power and 40,000uf of filter caps as well, but i think these LM3875's do sound better. I had to try the LM4780, just to see if there was a difference. I think this chip is slightly more cleaner sounding
The LM4780 gives a great punch but lacks the subtleties and the finesse of the LM3875, oh s......t i don't know, it just sounds better
Anyway I'm very happy with the sound
Tri amp completed gmphadte Solid State 10 26th June 2007 04:51 PM
25w amp completed pudge667 Solid State 2 9th May 2007 08:57 PM
Completed and cased LM3875 chipamp for sale. CJ Paul Swap Meet 0 10th July 2006 07:30 PM
Page generated in 0.09201 seconds (78.63% PHP - 21.37% MySQL) with 11 queries
