Old 9th September 2006, 09:29 AM   #1
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Default Bridged GC according to National application sheet
I want a GC with more power to drive some OB speakers. Should I go with bridged or parallel design?
I think from what I have read, more current is better with OBs but would like some expert opinion before I start soldering.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 9th September 2006, 12:10 PM   #2
Hi Nuuk,
This sounds interesting, what are you planning on using the 4870?
Old 9th September 2006, 01:19 PM   #3
Nuuk's Avatar
Nope - LM3875!
Old 9th September 2006, 06:04 PM   #4
Default Bridge or parallel
What series of OB's? they seem to have a pretty high sensitivity level 94 to 96db 1W1M and there impeadance seem's pretty normal 6 to 8ohm range, they do seem to have a little more complex frequency/impeadance curve.
I would go with a bridge if the impeadance wont drop below 6 to 8 ohms but only with a +/- 25 to 28VDC supply, as to keep the dissipation down.
If these things are really impeadance monsters I would go parallel at a higher supply voltage +/- 35VDC.
If you really want some get up and go, go with a BPA solution.
Old 9th September 2006, 07:00 PM   #5
Nuuk's Avatar
I'm running Hawthorne AUdio SIs at present. My Goodmans 201s are quite happy with a single-chip amp but they don't have to go so low as the SIs.
I'm using a single LM3875 IGC at present but comparing it with an Autocostruire CT MC4x100 (with the outputs paralleled) it feels like I could do with a bit more power for listening loud.
I've got a 28 volt regulated supply I can use so that's not a problem.
I just don't need as mch power as the BPA200 provbides.
Old 10th September 2006, 08:06 AM   #6
owen is offline owen  United Kingdom
Nuuk,
I'd go BPA too... That way, you get heaps of current and Voltage to provide solid load tolerance - you never know when you might just need it
Owen
Old 10th September 2006, 08:22 AM   #7
Nuuk's Avatar
Well you should at least have an idea when you will need all that power Owen!
I'd have to buy more chips for BPA and this is intended to be a low cost project. In fact, even if I had enough chips, I would be tempted to build one bridged, and one paralleled GC, just to find out which did sound better with the OBs.
National ICs for PCBs elementx Swap Meet 16 26th July 2007 06:55 AM
National TV davidallancole Solid State 9 8th August 2006 12:25 AM
National IQ test. Circlotron Everything Else 33 24th January 2005 12:52 PM
National.com audioPT Everything Else 4 10th September 2002 03:39 PM
National LM 1972 Herman Solid State 12 10th September 2001 08:18 AM
Page generated in 0.09114 seconds (74.43% PHP - 25.57% MySQL) with 10 queries
