I just recently purchased the lm4780 kit from Audiosector and am curious about how to use one transformer to power both chips. I plan to use THIS transformer to feed both chips. Each chip will be paralleled.
How should I go about using a single transformer to power both chips? I searched for nearly an hour on this subject but haven't found a good answer...
The power supply VCC and VEE (+ve and -ve) of each chip can be paralleled with the respective supply pins of other chip, and can be connected to a DC dual power supply..
As far as ur requirement is concerned the transformer o/p volts and VA is adquate for your requiremnt...U should rectify the dual a/c (25--0--25) with a diode bridge and filter with a pair of Electrolytic capacitors..and fed to the Chips via a pair of fuses..
Re: 1 trans 2 chips
Or the thing will simply not work, as I found out - the transformer is shorted out.
halo0925 said:...make sure you connect the same color wire to the same connection points on the rectifier boards, ....
So I can just use something like this
to connect the transformer to the rectifier boards?sangram wrote:
Measuring a power transformer with an ohm-meter often shows a very low value!
How did you determine that the transformer is shorted?Or the thing will simply not work, as I found out - the transformer is shorted out.
No no, this was not a toroidal which I had to experiment to find which leads were which. It was a custom-wound EI with terminal blocks for output, and it worked when not connected, or connected to only one of the rectifiers.
Peter's boards are arranged back-to-back. AC1 and AC2 of opposite boards are next to each other. If you connect thme to each other, it creates a short circuit for AC as each diode conducts to the ground leads for half a cycle.
Connecting AC1 and AC2 of each amp to their corresponding entires on the other side fixed it, so I knew it was the connection and nothing but that.
- Chip Amps
- One transformer, two chips
