Old 8th September 2006, 02:10 AM   #1
jpy1974 is offline jpy1974  United Kingdom
Default OPAmp replacement
Hi im new to all this but have really got the bug. Ive already upgraded the caps and opamps in my quad 405. I am now trying to upgrade the parts in my mitsubishi pre amp. If someone could spend a little time helping me i would be most grateful. The opamp in the pre is a m5214L is this chip any good or should i replace ?? if so what with. Can you still get this type of chip or would i need an adapter? and lastly would i just be able to swap them over without any mod to power supply??
Cheers, JP
Old 9th September 2006, 01:24 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
You may try the TLO7x series.If I was not mistaken,Quad did use some of them in their products.
Old 9th September 2006, 01:35 AM   #3
astouffer's Avatar
According to the datasheet the m5214L looks like an amplifier in a SIP package. Not many modern opamps are available that way. You could either find something in a TO-39 package or wire up a small adapter board with a DIP/SOIC chip.
Old 11th March 2007, 09:54 PM   #4
what datasheet. i cant find one for this IC.
Old 12th March 2007, 08:47 AM   #5
the minimum you need is a schematic for the amplifier and the datasheet for the chip.
Then you can see what the manufuacturer recommends and what the assembler did with it.
Without that you are groping in the dark.
regards Andrew T.
Old 12th March 2007, 01:14 PM   #6
Nordic is offline Nordic  South Africa
Nordic's Avatar
use google, type datasheet and the partnumber....
best opamp replacement for TL07x? SemperFi Instruments and Amps 8 21st December 2009 06:59 PM
JRC 4556AD opamp Replacement? Pyre Digital Line Level 3 27th February 2009 09:16 AM
DC300A opamp replacement ks-JPN Solid State 0 30th October 2008 06:17 AM
Opamp Replacement Help tone Digital Source 1 19th August 2002 04:41 PM
5532 opamp replacement 2Bak Parts 7 5th May 2002 03:43 AM
Page generated in 0.08443 seconds (72.38% PHP - 27.62% MySQL) with 10 queries
