What amp for tweeter only in active setup ?
Old 7th September 2006, 01:47 PM   #1
Groundloops is offline Groundloops
Im amazed!
Groundloops's Avatar
Question What amp for tweeter only in active setup ?
I wonder what kind of amp to use to drive the tweeters only in an all active 2-way setup ?
Speakers are Jim Griffins MiniMonitors (Jordan JX92s / Aurum Cantus G2Si crossed at 3 kHz with 18 db/oct.) For the lower octave I use a pair of MyRef Rev C monos, xover is a heavily modified Behringer DCX2496.
What would you do - just use another amp that comes along ?
Old 7th September 2006, 02:18 PM   #2
kepa1 is offline kepa1  France
Talking about tweeters in active filtered set ups, I've read about a French guy pluging his Fostex FT66 straight, in his active filter, you read good... no amplifier!
I've not tested it yet, especially because my DCX is broken right now, but I'll definitely give it a try. Apparently you need high sensitivity tweeters (>100db) to achieve a convenient sound pressure level.
Alternatively, I'd add another amp of the same manufacturer.
Bye
Old 8th September 2006, 12:07 PM   #3
Im amazed!
Nice suggestion, but Im not sure if a tweeter with 6 ohms nominal impedance is an adequate load for an opamp.
Old 8th September 2006, 01:40 PM   #4
6ohm is too low even for a line driver designed to push big current into a pair of 50ohm terminated coax.
regards Andrew T.
Old 8th September 2006, 06:57 PM   #5
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
This may be of interest!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 9th September 2006, 02:22 AM   #6
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Default Re: What amp for tweeter only in active setup ?
How about LM1875???
What amp for tweeter only in active setup ?Hide this!Advertise here!
tri-mono active setup? Bad silver Car Audio 3 20th May 2010 03:57 AM
Amps for active crossover setup jamikl Multi-Way 8 16th February 2009 11:13 AM
Cheap active setup. JZatopa Digital Source 0 20th March 2005 02:16 AM
what type of capacitor to protect tweeter in active filter setup timsch75 Multi-Way 8 9th December 2004 11:53 PM
DIY active HT setup Alex M Multi-Way 7 18th November 2001 12:20 PM
Copyright ©1999-2017 diyAudio
