Old 6th September 2006, 06:51 AM   #1
xiaonan is offline xiaonan  China
Default need a high voltage operational amplifier!
I want to set up a digital controled voltage supply. I need a high voltage operational amplifier which can provide 0~100V output voltage at lease. But I can not find a op-amp like that?
Is there someone know some op-amp about that? Or know some circuit can get the same result?
Thank a lot!!!
Old 6th September 2006, 07:38 AM   #2
Default Re: need a high voltage operational amplifier!
http://eportal.apexmicrotech.com/mai...linvoltage.asp
is your friend!
Old 6th September 2006, 07:50 AM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Re: need a high voltage operational amplifier!
Thank a lot!!!
is your friend!
It is NOT easy to find such OP-Amps.
They exsists, but the demand is limited, so difficult to find.
APEX as mentioned, is wellknown to have those circuits
at a somewhat higher price.
My own approach, because I have the knowledge
would be a custom discrete OP-Amp for your project
using higher voltage transistors.
Search google:
"discrete op amp" "high voltage"
http://www.google.se/search?q=%22dis...igh+voltage%22
regards
lineup
PS. you may have heard the song:
I'm an alien I'm a legal alien
I'm an Englishman in New York
It is written by an english man: STING
His official website here http://www.sting.com/
I'm a China man in Arizona
I love those aliens.
We all are! .... in some way ...
/your true friend lineup
lineup
Old 7th September 2006, 06:45 AM   #4
glennb is offline glennb  Australia
Thank a lot!!!
Consider the LM4702 - Stereo High Fidelity 200 Volt Driver with Mute at http://www.national.com/pf/LM/LM4702.html. There are several threads in this forum on its use as an audio power amp output stage driver. There is no reason why it couldn't be used in a power supply.
Glenn.
Old 7th September 2006, 03:37 PM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
or the old LM12
Old 7th September 2006, 04:16 PM   #6
jackinnj's Avatar
It can only source or sink a few mA if used on its own -- and is pretty expensive for this purpose --
The circuit below is, essentially, that which appears in the Art of Electronics -- and it works -- I have used it with AD811, AD825, LT1013 etc., as the error amplifier -- it can also be configured as a negative side regulator. It uses a Voltage DAC on the input -- the potentiometer controls the gain of the loop. You will have to figure out the values of compensation capacitors for yourself since I just plugged these in to see the affect on loop response.
Old 7th September 2006, 04:37 PM   #7
http://www.edn.com/article/CA45890.html
Have a look at this. It talks about bootstrapping op-amps to have a larger voltage swing.
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
Dual Operational Amplifier Question? lindomar Class D 3 7th October 2007 08:09 PM
How (Not) to Decouple High-Speed Operational Amplifiers Ruach Digital Source 24 17th October 2005 01:50 AM
High voltage umbilical and connectors / 1 box for PSU 1 box for amplifier in kit88 PTSOUNDLAB Tubes / Valves 30 10th September 2003 07:45 PM
Solid-State High Voltage Amplifier G-Daddy Solid State 6 18th December 2001 05:10 PM
Page generated in 0.11192 seconds (80.64% PHP - 19.36% MySQL) with 11 queries
