| Chip Amps Amplifiers based on integrated circuits |
Is the resistor current limit is only a common resistor or a resistor with coil?
#2 | |
"Internal current limit circuitry can be user-programmed with a single external resistor, protecting the amplifier and load from fault conditions." Page 6 describes the feature in detail.
Glenn. |
#3 |
On further examination, it looks like someone has doctored an image cut from the datasheet, added the R1/C1 Zobel network and removed the 'External' caption from below RCL.
The datasheet does not refer to using a Zobel, so RCL does not include the resistance of a coil (inductor). I would put a Zobel (whether R/C or R/L/C) *after* RCL, so that it is more closely associated with the load.
Glenn. |
#4 |
Thank u so much Glennb.
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Capacitor Question /question on cap | TunaFish | Tubes / Valves | 14 | 12th January 2004 02:23 AM |
| PS question - tformer question actually | breguetphile | Chip Amps | 2 | 30th May 2003 01:29 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.08325 seconds (72.16% PHP - 27.84% MySQL) with 11 queries |
