| Chip Amps Amplifiers based on integrated circuits |
My question is: four primary leads-- 0v white; 117v yellow (first primary) (second primary)-- 0v orange; 117v black.
The dual secondary is 24v x two. Product note states; primary leads connect in series or parallel. 117/234 v. Should the secondaries connect to a single primary(117v)? Or, can they be connected; primary 1 to secondary 1 & primary 2 to secondary 2? Note: will use 2 bridge rectifiers Help will be 'much' appreciated. larryg
larryg |
#2 |
Did it Himself
The secondaries don't connect to the primary at all.
I strongly suggest you put whatever project you have on hold and read some basic electrics before you proceed, you seem awfully close to death.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
I agree with Ritchie 100%!
Start here and make quite sure that you at least know the basics before you even go near the mains supply!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
THANKS FOR YOUR REPLY RICHIE&NUUK. IN USING THE WORD
[ CONNECT ], I MADE A POOR CHOICE IN MY POST. I DO KNOW THE PRIMARIES(ONE OR TWO) CONNECT TO THE MAIN, THE SECONDARIES TO RECTIFIER(S), FOR THE REQUIRED DC. THE MAINS, FOR THE U.S., IS 117V. SO FOR THE TRANSFORMER, ONLY 0NE OF THE PRIMARY LEADS IS CONNECTED TO THE MAINS,117V. FOR MAINS OF 234V, BOTH TRANSFORMER PRIMARIES ARE USED. IS THIS CORRECT? IN FUTURE POSTS, I WILL PAY MORE ATTENTION IN CHOICE OF WORDS! THANKS, larryg
larryg |
#5 |
#6 |
THANKS NUUK, larryg
larryg |
#7 | |
one rectifier will do the job and is cheaper/simpler. You can use two rectifiers to get a slightly increased current if your diode bridge is too near it's rating limits. If you use only one 117V primary you will massively reduce the VA rating of the transformer. It will be either 50% or 25%, I can't get closer than that.
regards Andrew T. |
#8 |
Did it Himself
The two rectifier bridge approach gives a better quality ground and loading of the transformer. The matter would be slight for a gainclone though.
#9 | ||
Similarly Quote:
regards Andrew T. |
#10 |
Did it Himself
I thought I had already explained both these points to you sometime in the last couple of months. IIRC you said you were going to look into what I said, but I never saw anything back from you.
| Use a single secondary x-former as dual PSU? | pixworld | Chip Amps | 7 | 9th March 2009 01:32 PM |
| dual secondary transformers | jesserparker | Chip Amps | 14 | 13th January 2007 01:25 PM |
| center tap to dual secondary conversion | neutron7 | Parts | 4 | 30th November 2005 10:08 AM |
| Dual center tap secondary | scottw | Power Supplies | 0 | 18th September 2005 08:54 PM |
| Dual primary wiring for Plitron standard toroid | sardonx | Chip Amps | 6 | 3rd August 2005 06:16 AM |
| Page generated in 0.08928 seconds (85.90% PHP - 14.10% MySQL) with 10 queries |
