| Chip Amps Amplifiers based on integrated circuits |
#21 |
Good day! I have two boxes for my project; the first is for the amps, volume control, in/out, both channels.
The second is for the psu/bridge rectifiers ( some suggest placing the bridges in amp box?) Will be using xlr's to connect. (NOW?) For the grounding between the boxs. Any suggestions for this? larryg
larryg |
#22 |
the first box containing the transformer is mains powered. It must have a safety earth. The second box is not mains powered. Can you guarantee that your construction will never introduce the risk of mains appearing on/in the second box? If yes then you do not need a safety earth. If you are in any doubt then be safe put in a safety earth. Do not connect any of the safety earths to audio ground. The wires coming from the PSU box to the Amplifier box do not contain any grounds. I can hear you asking "has this guy gone crackers". The PSU wires are +ve supply, 0volt supply and -ve supply. You can call the 0volt supply the PSU common if you prefer. BUT IT IS NOT a ground. If you can get your head to think in this direction you are less likely to make a grounding error that will afflict your amp with hum.
regards Andrew T. |
#23 |
Hi AndrewT. A very 'good' answer for me, 'Your' knowledge and of
others, helps me a great deal; and many others, past & present, I'm sure would agree. Thank You, larryg
larryg |
| Use a single secondary x-former as dual PSU? | pixworld | Chip Amps | 7 | 9th March 2009 01:32 PM |
| dual secondary transformers | jesserparker | Chip Amps | 14 | 13th January 2007 01:25 PM |
| center tap to dual secondary conversion | neutron7 | Parts | 4 | 30th November 2005 10:08 AM |
| Dual center tap secondary | scottw | Power Supplies | 0 | 18th September 2005 08:54 PM |
| Dual primary wiring for Plitron standard toroid | sardonx | Chip Amps | 6 | 3rd August 2005 06:16 AM |
| Page generated in 0.09365 seconds (70.79% PHP - 29.21% MySQL) with 10 queries |
